Toymods » Tech & Conversions » SAFC II + AVCR + FCD HELP!
tyottsoarer
Gold Coast
icon5.gif  SAFC II + AVCR + FCD HELP! Thu, 03 February 2005 12:24 Go to next message
So i have preaviously installed an AVCR myself on my tt auto soarer with great results. I then installed a HKS fuel cut deffender (FCD) to raise the fuel cut slightly. The FCD spliced into the pressure signal (I'm guessing it is the map sensor signal). By spliced i mean the signal wire was cut, signal from engine went into 1 side of the FCD and then fed into the ECU. I then bought an SAFC II and read the installation instructions. The SAFC II also cuts into the pressure singal the FCD does.
My question is can both these items (SAFC II + FCD ) be used together, because as far as i know they both modify the singal the ecu recieves, would one cancel the other out? or do they modify the signal in different ways? If this is so can anyone tell me how each modifies the signal?
Also, the readouts from the avcr and safc are slighty different where they have been spliced into the same signal like RPM and throttle readouts, is there a reason for this?
And finaly can these to piggy back units be made "aware" of each other. I can recall ready that the safc can "trace" avcr functions.
[Updated on: Fri, 04 February 2005 16:15]
Fr3aK
Wollongong
January 2005
Re: SAFC II pressure sensor question Fri, 04 February 2005 07:22 Go to previous messageGo to next message
Is the pressure sensor the wire you had to cut? If not, which one did you have to cut?
If it's only spliced, you can 'tap' shit into it all day long. There should be diagrams in the manual how to 'daisy chain' all of the A'PEXi products.
tyottsoarer
Gold Coast
Re: SAFC II pressure sensor question Fri, 04 February 2005 10:36 Go to previous messageGo to next message
Yep, wire has to be cut , wire coming from engine feeds into the safc , then another wire off the safc loom re-attaches to complete the conection.
Re: SAFC II pressure sensor question Fri, 04 February 2005 10:43 Go to previous messageGo to next message
do both devices have high enough impedance to allow the signal to be tapped without altering it too much?
why not run a new pressure sensor just for the SAFC?
Fr3aK
Wollongong
January 2005
Re: SAFC II pressure sensor question Fri, 04 February 2005 10:51 Go to previous messageGo to next message
I say put the FCD splice BEFORE the SAFC. That way, it'll still work with your existing tune, while retaining its integrity.
But always, if in doubt, call a performance shop which installs these devices.
tyottsoarer
Gold Coast
Re: SAFC II pressure sensor question Fri, 04 February 2005 16:13 Go to previous messageGo to next message
I re-wrote the original post to include a few more questions and details.
Chris Davey
sunny coast, qld
Re: SAFC II + AVCR + FCD HELP! Sat, 05 February 2005 01:11 Go to previous message
I think the way Freak said to do it is the correct way.
My mate was about to install his SAFC in his jzz30 which has an Apexi RSM which also uses the signal from the pressure wire and he explained it to me how Freak said.
Previous Topic:Timming a 3tgte
Next Topic:Changing suspension on AE92
Current Time: Thu Oct 22 14:51:23 UTC 2026
Total time taken to generate the page: 0.0042080879211426 seconds
