Toymods » Tech & Conversions » W58 - serial numbers or identifiers
no_tofu_speed
Jab what?!!?!
W58 - serial numbers or identifiers Thu, 03 February 2005 13:12 Go to next message
I have been doing a search through the forums on W58's.
It is apparent that there are 4 different shifter positions.
"There are 4 stick posi the most common is staight up then 35 mm then 55mm back but there is also a rare 1 that is 25 mm fwd to the straight up posi".
And also the issue of the great later being the strongest.
And if it was a tranny released with a non-turbo or a turbo engine (I am guesisng there would be strength differences).
Are there any unique serial numbers or identifiers that can be used.... well to identify the variant of W58. Quite helpful when trying to find out what box someones is selling...
Another newbie Q, What is a R154 from?
Re: W58 - serial numbers or identifiers Thu, 03 February 2005 13:26 Go to previous messageGo to next message
If you're looking at an early W58, the easiest way to tell if it was actually a W58 would be the steel sandwich plate, but this isn't always the case.
The simplest way to tell a Mk4 W58 would be the f'ed up shifter extending off the back of the box.
Re: W58 - serial numbers or identifiers Thu, 03 February 2005 14:11 Go to previous messageGo to next message
Actually, most early W58's have alloy sandwich plate.
Even some MA70 W58's have alloy sandwich plates.
Only real way to tell is 5th gear ratio. (Its the only part that differs between it and the W57)
As for the shifter posi
MA61/RA65/RA60 .......... ......????...... ........... ........... GA70/MA70/MX73...... ............. SA63
http://www.oz-enet.com.au/~peewee/Toyota_Supra_5spd_Shifter.jpg
Thats where to find what shifter posi's.
[Updated on: Thu, 03 February 2005 14:12]
Re: W58 - serial numbers or identifiers Thu, 03 February 2005 14:15 Go to previous message
Oh, and R154 was behind all manual 7MGTE's and 1JZGTE's (MA70, JZA70, JZX81, JZZ30 etc etc)
Previous Topic:Which engine
Next Topic:sprinter traction problems
Current Time: Sat Oct 24 04:37:49 UTC 2026
Total time taken to generate the page: 0.0045549869537354 seconds
