Toymods » Tech & Conversions » 1g standard clutch
1ggte89
1g standard clutch Thu, 03 February 2005 14:48 Go to next message
my clutch is slipping like a mad cunt when i bought my car its got the standard turbos but aftermarket ecu
would the standard clutch do the job with the boost up to say 14psi or would it be best to get a daiken HD clutch i am a student so money is a factor Razz Sad
Re: 1g standard clutch Thu, 03 February 2005 14:50 Go to previous messageGo to next message
If you're a student, the intermediate option of the HD clutch is a good idea. While it's a little bit more expensive (and in reality, it's not that much more) it shouldn't have any problems keeping up with your driving Smile
HyDrA
Adelaide, SA
Re: 1g standard clutch Thu, 03 February 2005 22:45 Go to previous messageGo to next message
How much money are you willing to spend?
You might want to get a new pressure plate along with the clutch plate.
Give these guys a call: http://xtremeclutch.com.au/
They set me up with my clutch and it works damn nice (heavy duty organic), does chirpies in 3rd easily Wink
Fattony
Re: 1g standard clutch Thu, 03 February 2005 23:10 Go to previous messageGo to next message
HyDrA
Got my clutch of the same mob and it is fanstastic, though i did have to modify the position of the slave relitive to the fork (there was to much free play in it) but after i sorted that the clutch cant be faulted, though i do have a cushion button 9 puck with a 1000kg+ centre, but for the price of 500 which included flywheel maching its fairly cheap unit, though i did install it myself.
Cheers Adam
HyDrA
Adelaide, SA
Re: 1g standard clutch Fri, 04 February 2005 00:34 Go to previous messageGo to next message
Yeh if you go nuts on the clutch you're gonna have trouble anyway Razz
They're about 5 mins drive from my place (the actual xtreme clutch place) so I can get myself clutch bits easily... they also do some brakes I believe.
Bugman
Re: 1g standard clutch Fri, 04 February 2005 06:11 Go to previous messageGo to next message
I spent $450 on a 5puck with a ~900kg PP bearings and flywheel machine.
Re: 1g standard clutch Fri, 04 February 2005 07:23 Go to previous messageGo to next message
I spent $418 getting my pressure plate upgraded to around the 1000kg+ mark, and a heavy duty clutch plate, machined flywheel and new thrust bearing.
1ggte89
Re: 1g standard clutch Fri, 04 February 2005 07:58 Go to previous message
i can get a hd daiken clutch for $300 and a mate was gona machine the flywheel. a mate had one of these in his 180 and he said its a good clutch so i might get it. thanks for the info
gona have to get the hd .. Cool
Previous Topic:Radiator problem ??
Next Topic:MA70 Diff Question - Clutch or Torsen?
Current Time: Tue Nov 24 20:23:30 UTC 2026
Total time taken to generate the page: 0.19197702407837 seconds
