Toymods » Tech & Conversions » VL turbo pump wiring/pipe configuration?
bayka
perth
icon5.gif  VL turbo pump wiring/pipe configuration? Thu, 03 February 2005 17:47 Go to next message
Yo ppl, FINALLY putting surge tank in on weekend (got hoses and little clampy things...YEEE Smile )
Need some help double checking positive/negative wiring and input/ouput nossels.
There is no marking for +/- terminals however one is physically bigger than the other, positive?
Im also assuming the fuel output to come out of the terminal side of the pump?
Please advise Surprised
-daniel-
http://members.westnet.com.au/bomrekab/VLpump.jpg
ZZT231
melbourne.vic.au
Re: VL turbo pump wiring/pipe configuration? Thu, 03 February 2005 19:51 Go to previous messageGo to next message
Go to http://www.calaisturbo.com.au - they should be able to help you...
Cheers.
flynn21atwork
Re: VL turbo pump wiring/pipe configuration? Thu, 03 February 2005 20:45 Go to previous messageGo to next message
Bigger terminal is positive.
Test flow rate before installing, so you know exactly how much fuel it will deliver, and you know it works. Makes it a bit easier when its out of the car, and spilling any fuel in the boot sucks, if that where your installing everything.
Make sure the pump is mounted lower than your surge tank of course. As they don't like to suck.
people100
Rocklea qld
Re: VL turbo pump wiring/pipe configuration? Thu, 03 February 2005 21:26 Go to previous messageGo to next message
yes big terminal is positive. there also should be a big nossel at one end. that is the end that goes to the surge tank and the smaller end goes to the engine... You are running a lift pump to get up to the surge tank????
bayka
perth
Re: VL turbo pump wiring/pipe configuration? Fri, 04 February 2005 10:20 Go to previous message
Ok thanks man, YES im using the standard in-tank pump as a lifter to the surge.
Smile
Previous Topic:3sgte help
Next Topic:Radiator problem ??
Current Time: Tue Nov 24 20:55:42 UTC 2026
Total time taken to generate the page: 0.086726188659668 seconds
