Toymods » Tech & Conversions » mx83 brake upgrade
i2obert
mx83 brake upgrade Thu, 03 February 2005 20:30 Go to next message
alright im upgrading my brakes on the cressie i got the r33 gtst calipers ford ba 300m slotted rda rotors and rear slotted rda rotors and pads from race brakes here in melb now im wondering will i need the o ring and plate made up ?? to fit the calipers i have herd some mx83s dont need it and some do i got a 1990 modle glx cressida ?? and any one got the messurments of the product needed and where i can take it to go get them made
Re: mx83 brake upgrade Fri, 04 February 2005 00:41 Go to previous messageGo to next message
I recently finished doing this upgrade on my MX83 struts. Here's a few photos:
http://members.optusnet.com.au/norbee/StrutUpgrade 2/default.htm
As you can see the calipers were a direct fit. The only fabrication work done was the locator ring.
DigitalAE86
Re: mx83 brake upgrade Wed, 20 April 2005 22:48 Go to previous messageGo to next message
Is there any difference between the front calipers on a R33 Turbo and an R33 Non Turbo?
I don't want to buy the wrong brakes.
EvilJack
Sutho/Hills NSW
Re: mx83 brake upgrade Wed, 20 April 2005 23:42 Go to previous messageGo to next message
http://members.optusnet.com.au/norbee/BrakeUpgrade /default.htm
looks like you changed your site around a bit norbie Razz
ColMX83
Re: mx83 brake upgrade Fri, 29 April 2005 07:47 Go to previous message
I used the R32 caliper (300ztt and 200sx) and looks markedly different to the later ones, they have a fin sort of arrangement, so I'm pretty sure that if you get the rounded looking ones you will be right.
The R32 ones are designed for a 280mm disc and this can be done with a 10mm spacer between the caliper and mounting point. So if you use the original nissan disk size with this caliper, that's OK. It won't work with the 300mm ones
Previous Topic:GOOD TUNER FOR EMANAGE ON 1J IN PERTH
Next Topic:biggest size wheels to fit on a ke20
Current Time: Sat Nov 21 06:16:06 UTC 2026
Total time taken to generate the page: 0.0037751197814941 seconds
