Toymods » Tech & Conversions » max boost from twin ct12's ??????
gussyboy2
Oxenford/gold coast
max boost from twin ct12's ?????? Fri, 04 February 2005 06:40 Go to next message
i've been told ct12's should only be boosted to 15psi.
doesnt the length and size of intake come into the equasion?
has any one spooled them more than this?
YelloRolla
On your mum!
Re: max boost from twin ct12's ?????? Fri, 04 February 2005 07:12 Go to previous messageGo to next message
15psi is a loose way to give indication of shaft RPM.
Over speeding the turbos is what will kill them - if you can make a given boost at less shaft RPM then you can push the envelope further.
gussyboy2
Oxenford/gold coast
Re: max boost from twin ct12's ?????? Fri, 04 February 2005 07:16 Go to previous messageGo to next message
thanx YelloRolla.
was hoping they would push 20 with the two workin together.
gold28
Madrid - Spain
Re: max boost from twin ct12's ?????? Mon, 07 February 2005 00:25 Go to previous message
I am running 19psi on mine. They are currently on a Gen2 block. I think it is making about the same power as 16psi did in the gen3 block (150 rwkw. They seem to handle it Ok but I don't intend on keeping it at that pressure. Being a daily driver, I rarely hit high boost anyway so I'm not too worried. There is also some differences in the CT12 on a gen3 to a gen2. The casting on the compressor covers are slightly different. I am not sure if the internals changed though.
Previous Topic:Stuck clutch help..
Next Topic:RCA's don't fit!
Current Time: Sun Oct 25 02:36:14 UTC 2026
Total time taken to generate the page: 0.0086250305175781 seconds
