Toymods » Tech & Conversions » Cam angle sensor 4AGZE
L4AGZE
Manchester, UK
Cam angle sensor 4AGZE Fri, 04 February 2005 13:01 Go to next message
Hi everyone,
Just trying to get some info on the above as not getting a signal from the Cam angle sensor.
Ive done some searches and found that there are two types of CAS, magnetic reluctor and hall effect. How do you know which is which? I have a AE92 4AGZE with MAP sensor.
Also i think the wiring for a magnetic one is as follows:
RED: Trigger (pickup for 24 tooth wheel)
GREEN: Home pickup (TDC #1)
YELLOW: Home pickup (TDC #4)
WHITE: Common earth for pickups
As it has two pickups does this mean it calculates on half cycles or is there a wasted spark?
Any suggestions as to how to check if the unit is ok as i do know they can fail due to the air seal? going on them.
Thanks in advance
TE72_Turbo
Re: Cam angle sensor 4AGZE Fri, 04 February 2005 14:24 Go to previous messageGo to next message
They are magnetic reluctor.
Your wiring is correct.
They do run a wasted spark. I'm not certain what the factory computer uses the TDC #4 for, sequential injection perhaps? I thought you could still do that with only one home trigger though. Confused
Anthony Kellam
Re: Cam angle sensor 4AGZE Fri, 04 February 2005 14:47 Go to previous messageGo to next message
Theres a few reasons for that. For instance, twice as many "resets" (homes) per cycle means less worst case cranking before firing. Helps to sell cars Wink
As 1 and 4 are fired from the same ignition channel it doesnt matter which reset it is. Naturally you could do the same with two teeth on the top wheel but by this way you have same effect wilst maintaining exact engine position (handy for when they went to sequential injection/discrete ignition later).
L4AGZE
Manchester, UK
Re: Cam angle sensor 4AGZE Sat, 05 February 2005 10:58 Go to previous messageGo to next message
Thanks guys, TE72 I think it was from one of yourr posts that I got the wiring diagram.
So does anyone know how to get a signal from the sensor?
How can you check if the sensor needs replacing?
Thanks.
Re: Cam angle sensor 4AGZE Sat, 05 February 2005 11:11 Go to previous messageGo to next message
One way is to hook it up to a CRO and spin it with a drill, lathe, etc. and have a look at the signal...
L4AGZE
Manchester, UK
Re: Cam angle sensor 4AGZE Sat, 05 February 2005 14:39 Go to previous messageGo to next message
what do you mean by CRO ?
shinybluesteel
melbourne
Re: Cam angle sensor 4AGZE Sat, 05 February 2005 14:50 Go to previous messageGo to next message
Cathode Ray Oscilliscope
screeny thing that shows waveforms
L4AGZE
Manchester, UK
Re: Cam angle sensor 4AGZE Sat, 05 February 2005 16:36 Go to previous message
Of course not good with abbreviations!! Confused
Thanks!
Previous Topic:Exhuast Mainfold - 4AGE
Next Topic:corona mk2 and RT72 questions
Current Time: Wed Nov 18 04:51:25 UTC 2026
Total time taken to generate the page: 0.0055739879608154 seconds
