Toymods » Tech & Conversions » fly-cuts :: how deep to dig ??
ed_ma61
Lost in the K hole
icon4.gif  fly-cuts :: how deep to dig ?? Sun, 27 October 2002 14:17 Go to next message
im looking at a potentially machining 2 to 2.5mm deep flycuts into my pistons (which have samll flycuts in em already) to accomodate a nice lumpy cam...
anyone have an idea how to tell if this is too deep (thus compromising structural integrity of the piston) without sacrificing a piston and cutting it in half???
any general rules on flycutting i should know about?
rules of thumb for minimum clearance of valve to piston?
ed
allencr
tallahassee FL usOFa
Re: fly-cuts :: how deep to dig ?? Sun, 27 October 2002 15:42 Go to previous messageGo to next message
is this just to keep it non-interference? even though it's only necessary for "floating exhausts" and/or big lift & duration, the manufacturers seem to cut'm for both. probably so the piston can go in both ways.
i don't know
Youngy
Eskilstuna, Sweden
Re: fly-cuts :: how deep to dig ?? Mon, 28 October 2002 00:06 Go to previous messageGo to next message
This may not help you too much, but here goes.
I doubt if there is anyone on this forum who can give you the definative answer, I certainly can't and as fly cutting of pistons etc is a exacting art form due to the nature of pistons and valves not liking to touch each other I WOULD strongly suggest getting an engineering shop to answer your question.
Bill Sherwood
Brisbane / Gold Coast
Re: fly-cuts :: how deep to dig ?? Mon, 28 October 2002 01:58 Go to previous messageGo to next message
Depends on the piston, ie, if it's forged then 2.5mm should be thick enough for the metal on the top to hang together, and if it's cast then 3mm would be better. If you're running boost, then add about 0.5mm to that.
You need a clearance of 0.060" minimum from valve-to-piston at all times.
ed_ma61
Lost in the K hole
Re: fly-cuts :: how deep to dig ?? Mon, 28 October 2002 10:42 Go to previous messageGo to next message
ignore Sad
edited out wrong post in wrong field
ed
[Updated on: Mon, 28 October 2002 11:08]
ed_ma61
Lost in the K hole
Re: fly-cuts :: how deep to dig ?? Mon, 28 October 2002 11:04 Go to previous message
ok, how does this sound like for a plan:
#1- find spare piston and cut in profile where the existing flycuts are to see how much meat is in the piston crown.
#2- given they are cast, allow 3mm, and calculate max flycut depth
#3- install pison in block, rotate to TDC. install head on block, and set both intake and exhaust valves to required lift height (say 11mm).
#4- calculate how much material has to be taken out of pistons to allow above said 11mm valve lift plus an extra 1.5mm. compare to max depth as calulated in #2 and if ok, go machine it.
sound about right??
ed
Previous Topic:HKS Super AFR vs APEXi Super AFC
Next Topic:7M vs 5M intake manifold
Current Time: Thu Nov 19 21:39:50 UTC 2026
Total time taken to generate the page: 0.007512092590332 seconds
