Toymods » Tech & Conversions » phantom grip: who has tried it?
Sam_Q
S.E suberbs, Vic
phantom grip: who has tried it? Fri, 04 February 2005 16:08 Go to next message
I would like to hear from people who have played with a phantom grip in their diffs to see what their experiences are. Looks like a peice of crap to me but you never know.
TE72_Turbo
Re: phantom grip: who has tried it? Sat, 05 February 2005 00:49 Go to previous messageGo to next message
WTF is a "phantom grip"???
I need to know more!
alex_ta22
Newcastle, Hunter Valley
Re: phantom grip: who has tried it? Sat, 05 February 2005 01:06 Go to previous messageGo to next message
From what Sam_Q says, i think its an addictive for LSD diffs that are slipping.(just pulling this outta my a$$ though)
alex_ta22
Re: phantom grip: who has tried it? Sat, 05 February 2005 01:11 Go to previous messageGo to next message
"The Phantom Grip LSD, otherwise knows as Limited Slip Differential, conversion kit, installs into your non-lsd differential converting it into a proven and competitive limited slip differential that enhances your traction needs. It serves two distinctive functions for the daily driver, street/strip warrior, or full race vehicle. In cornering and braking, it functions as a disc-type limited slip. In hard acceleration, the Phantom Grip works as a locker causing both wheels to receive equal power instead of just one wheel spin"
[Updated on: Sat, 05 February 2005 01:13]
Sam_Q
S.E suberbs, Vic
Re: phantom grip: who has tried it? Sat, 05 February 2005 01:17 Go to previous messageGo to next message
yes that's the sales slogan, thanks Alex.
Basicly it's a crude mechinism that fits onto the shaft that holds the spider gears in place of a diff. It seems to be 2 blocks of metal that have 4 high compression springs pushing them apart. These put pressure on the spider gears and prevent them from slipping as much. I have been told that about a 30% lockup is acheived. It sounds like a load of crap to me but I am curious who has tried it.
alex_ta22
Re: phantom grip: who has tried it? Sat, 05 February 2005 01:27 Go to previous messageGo to next message
sounds like its up there with the hyclone and electric SC BS! Very Happy
TE72_Turbo
Re: phantom grip: who has tried it? Sat, 05 February 2005 05:22 Go to previous messageGo to next message
don't forget Brocky's "POLARISER" Razz
manmx83
Re: phantom grip: who has tried it? Sat, 05 February 2005 10:53 Go to previous messageGo to next message
dont knock the polariser! I have it on good advice Bertram had one in his winged keel. Shocked
Fattony
Re: phantom grip: who has tried it? Sat, 05 February 2005 22:04 Go to previous messageGo to next message
Wasnt the polariser one of the many reasons why holen HDT "brocky" parted, that and the fact he wanted to use IRS rear end.
Joshstix
Toymods Vice President
Re: phantom grip: who has tried it? Sun, 06 February 2005 23:41 Go to previous messageGo to next message
A few of the MR2 guys in the US have tried the phantom grip. I believe they have also all tried the "tranny rebuild" since then. The thing just uses friction to put pressure on the spider gears and ends up pumping metal shavings through the diff.
fangsport
timaru NZ
Re: phantom grip: who has tried it? Mon, 07 February 2005 10:53 Go to previous messageGo to next message
before you bag the whole concept, try doing a bit of imformed reading/research.
these units DO work. they are not as good as a decent LSD , but are also well off the price of one.
Toymods » Tech & Conversions » 86: Alternatives to T-series rear-end for LSD & discs?
Sam_Q
S.E suberbs, Vic
Re: phantom grip: who has tried it? Mon, 07 February 2005 11:25 Go to previous messageGo to next message
yes I am familiar with that thread fangsport however I dont beleive that someone said they had actually tried it
fester
Gympie Qld
Re: phantom grip: who has tried it? Mon, 07 February 2005 11:38 Go to previous messageGo to next message
Here's something I found when searching about it.
After taking the time (or paying someone) to remove the trans, open it up, modify the diff, reinstall the trans, blow up the diff, try to find a new one hoping that chunks of metal did not ruin the rest of the trans, opening it up again and removing the bad diff and reinstalling a new diff, and reinstalling the trans, the price of the quaife is more than worth it. Did I also mention aligning the car every time you remove the subframe?
And this is considered the best case scenario. Worst case is it ruins your entire trans, while leaving you stranded in some ghetto.
Was some pretty nasty photos as well but I don't know how to post pictures into this forum.
cars were some Yank Ford FWD's I think but they also commented that they seemed to work Ok in some other models.
Sam_Q
S.E suberbs, Vic
Re: phantom grip: who has tried it? Mon, 07 February 2005 11:49 Go to previous messageGo to next message
sounds right to me Fester. Although I asked who tried it I never at any point I wanted to use it. My engeneering sense says that using a metal to metal contact for a source of friction is fundametally flawed, let alone on the end of a spider gear that has such a tiny surface area. I was curious if anyone actually went ahead with it. Whats really funny is that apparently this device is made from mild steel!! imagine the effects of this thing rubbing against the super hard spiders, it would be demolished. So hold on now that I think about it that's how it works, it is of a mild steel so it causes resistance by tottaly mincing itself, ingenious!
So guys lets put this device on the shelf next to the Turbo-zet as the nice try section and let this thing go, case closed!
irishtwincam
Ireland
...a phantom grip unti DESTROYED this box... Mon, 07 February 2005 12:54 Go to previous message
PG destroyed this gearbox
http://homepage.mac.com/dgiessel/.Pictures/car/pha ntom_grip/
homepage of PG
http://www.azracemachine.com/TwinTracDesc.htm
Previous Topic:Best 2 Ltr Engine???
Next Topic:18r-g flat spot - 2000-3000 rpm
Current Time: Sat Oct 17 04:07:23 UTC 2026
Total time taken to generate the page: 0.010998964309692 seconds
