Toymods » Tech & Conversions » T-18 T50 -> AE71
gearb0x
T-18 T50 -> AE71 Fri, 04 February 2005 21:09 Go to next message
Hey
I'm putting a full T-18 driveline into a AE71 and i was wondering if the AE71 X-member will be fine for the T-18 T50 (i assume so) as well as whether or not i can use the whole T-18 Tail shaft
I think it should be fine if i use the T-18 Tail shaft with the AE71 GB X-member, but i could be wrong (up until i checked 10 mins ago i thought the T-18 GB xmember was a straight bolt in too Smile )
Also, the motor will be T series. Ive seen karl skew's article where he used A series mounts and a 10mm spacer on one side of the engine to put a 3TC into his AA60 so i was thinking something similar, otherwise i might have to try my hands at fabricating engine mounts. I don't want to swap cross members as i want to keep it intact for a possible later more 4a like conversion Very Happy
jesseT18
Castle Hill, Sydney
Re: T-18 T50 -> AE71 Fri, 04 February 2005 23:34 Go to previous messageGo to next message
why not just weld the rack mounts from your a xmember onto your t series x member and when you get a 4AGZZTTE just grab another a series crossmember from wreckers?
this is my plan if i got R & P in the T-18
TE72_Turbo
Re: T-18 T50 -> AE71 Sat, 05 February 2005 00:43 Go to previous messageGo to next message
The gearbox crossmembers from my T18 & AE71 were identical. Are yours different? Confused
[Updated on: Sat, 05 February 2005 00:43]
gearb0x
Re: T-18 T50 -> AE71 Sat, 05 February 2005 00:54 Go to previous messageGo to next message
TE72_Turbo wrote on Sat, 05 February 2005 11:43
Hmm i woulda thought they would be the same too
unless i grabed the wrong cross member Embarassed im pretty sure its a T-18 one, oh well ill just have to get under the T-18 that works and measure the difference, fuck knows where i got the cross member i tried then Wink
(the crossmember was from the updated shape T-18 but i dont think that would be any different)
gearb0x
Re: T-18 T50 -> AE71 Sat, 05 February 2005 01:28 Go to previous messageGo to next message
just went and checked again, there is 1" difference between the bolt holes
i dont have a AE71 crossmember to compare to though
Ill see how i go once i start the conversion, if they are DEFINATLY different and im not fucking anything up, ill just get an AE71 one, should do the job Smile
Re: T-18 T50 -> AE71 Sat, 05 February 2005 02:28 Go to previous message
when i did this swap there was a couple of things to note:
If using the T18 t50 box with the AE71 bellhousing, you have to be VERY careful with the thrust washers etc and make sure they are the right height. It was a bit of a pissfart around, but there was some combination of the washers that worked when i measured them up.
The AE71 gbox xmember is different. Use it.
Use the T18 complete tailshaft if you are using the T18 gbox and diff.
Everything else bolts up.
Previous Topic:Can anybody show me GZE base ignition map?
Next Topic:1jz/2jz ignition systems
Current Time: Tue Oct 27 03:51:56 UTC 2026
Total time taken to generate the page: 0.013867139816284 seconds
