Toymods » Tech & Conversions » 4age head swap
normo
Tamworth NSW
4age head swap Sat, 05 February 2005 10:33 Go to next message
I'm so confused
so far i have heard on these forums og guys putting 20V heads on 4agze's, or puttin 16V heads on 20V engines.
I want to improve power on a 4age, can I bolt on 20V head currently I run a big port with twin side draft carbs, no room to run efi.
Will it work?
is the main difference in a 20V in the head?
IRA11Y
Club Member
Re: 4age head swap Sat, 05 February 2005 10:35 Go to previous messageGo to next message
I wouldnt call myself an engineer but Id be guessing the difference in the head might have something to do with one bieng called a 20V and the other a 16V Rolling Eyes
normo
Tamworth NSW
Re: 4age head swap Sat, 05 February 2005 10:44 Go to previous messageGo to next message
Not nice
I can count 20V 16V
rthe blocks, the blocks will the 16v block accept the 20v head and give equivalent power to a 20V?
That's the question
feral4mr2
Bundaberg, Qld.
Re: 4age head swap Sat, 05 February 2005 12:28 Go to previous messageGo to next message
there might be noticable power increase from the extra flow (debatable compared to a 16v bigport head) from useing the 20v head. the 20v engine also uses higher compression ratio to help give it it's extra power output over a 16v 4age.
normo
Tamworth NSW
Re: 4age head swap Thu, 10 February 2005 08:13 Go to previous messageGo to next message
bummp
Flem
cambo
Re: 4age head swap Sat, 12 February 2005 23:56 Go to previous messageGo to next message
THE VALVE CUT OUT ON THE PISTONS 4 cut outs compared to 5 not saure if it would hit though
4agte
Toronto, Downtown
Re: 4age head swap Sun, 13 February 2005 00:05 Go to previous messageGo to next message
the 20v's also rev more than 16v's
IRA11Y
Club Member
Re: 4age head swap Sun, 13 February 2005 00:28 Go to previous message
interesting statement... exactly what do you base this on?
just curious because AFAIK the head is not the limiting factor in peak rpm on a 4AGE , its more to do with crank and stroke , now considering the stroke is still the same across the 4AGE range that leaves the crank. FA uses a 40mm main crank like a bigport and they generally rev @ 10000rpm or so.
ecu rev cut is not an indication of an engines ability to rev, although the manufacturer sets the rev limit based on peak torque and longevity of the engine.
generally a 20V will have the torque higher in the rev range but thats a factor of the flow of the head and cam profile not the ability to rev more.
so what evidence do you have to support the theory?
EDIT: forgot to add CR can be a factor too
[Updated on: Sun, 13 February 2005 00:29]
Previous Topic:Hi Flowing a ct20
Next Topic:RB25DE / R33 GTS wiring diagrams
Current Time: Thu Nov 19 09:31:09 UTC 2026
Total time taken to generate the page: 0.0065429210662842 seconds
