Toymods » Tech & Conversions » car will not start
MR. 2
Parramatta
car will not start Sat, 05 February 2005 11:10 Go to next message
guys my car wont start at the moment i think its the coil thats has no spark, but i cant be sure whats the best way to check this.
I have taken the lead off the dizzy and then put a screw driver onto it and then to earth and there was no spark from it at all when i tried to crank the car... is this normal???
I have checked all of the leads none have spark as i put a screw driver into them and then earth them also an no sparks jumping. I also have checked the plugs and they are no fouled.
any ideas???
MR. 2
Parramatta
Re: car will not start Sun, 06 February 2005 01:27 Go to previous messageGo to next message
oki have changed the coil now and the old one seemed to be rooted... however its still not starting could it be that the ignighter is screwed... its an aftermarket one EMS?
any ideas
fade-e
Re: car will not start Sun, 06 February 2005 06:04 Go to previous messageGo to next message
since replacing the coil is there spark now?
also with the ignitor get a test light and have the car in reds to see if there is electricity going through
MR. 2
Parramatta
Re: car will not start Sun, 06 February 2005 21:49 Go to previous messageGo to next message
still no spark i will test the ignighter, thanks
Jorrs
Coffs Harbour
Re: car will not start Mon, 07 February 2005 05:21 Go to previous messageGo to next message
if u leave ya car in the sun 4 a while will it start then ?? i had exact same probs with my car i replaced the ECU ignitor,coil, all leads, dizzy,and distributor and also the spark plugs and it still wouldnt start, it turned out it was my AFM that was bugggered and would only start when it was in sun and was a bit hot and would heat up the AFM and the lil sensors in it would work then but yeh goodluck with it it ended up costin me a lot of money to fix.
styler
Re: car will not start Mon, 07 February 2005 06:50 Go to previous message
screwdiver? eh????
and then to earth??
why not put another spark plug into the leads and
hold it on the block to check spark?
i take it you are leaving a gap between the screw driver
and earth too.
check there is power to the coil and the condition
of leads/dizzy whole system etc.
maybe its not the coil because there are multiple
start up problems, usually electrical/fuel though!
Previous Topic:5MGE Auto pin outs? ECT not ECU
Next Topic:headlight upgrade on RA23
Current Time: Sun Oct 25 15:46:04 UTC 2026
Total time taken to generate the page: 0.19165802001953 seconds
