Toymods » Tech & Conversions » 4K no spark, help?
purple_people_eater_1
Hobart, Tasmania
icon9.gif  4K no spark, help? Sun, 06 February 2005 11:26 Go to next message
My KE70 with a 4k suddenly died on me the other day, I turned a left hand corner and it cut out I pulled up check over the engine hopped
in the car and it started, drove in a straight line turned left
again and it died, however it wouldnt run after this.
Ive replaced the rotor button, distributor cap, points and coil.
but its done nothing, turns ova no spark not even from the coil.
The balast resistor is getting really hot.
Cant seem to find it shorting out anywhere.
Anyone have any ideas? has quite a few people baffled.
Thanks Kieran
gr8r-x
Vic, AU
Re: 4K no spark, help? Sun, 06 February 2005 11:39 Go to previous messageGo to next message
If the resistor is getting hot, there must be a short somewhere close to it.. Apart from that, I can't help much, as you've already replaced what I would've suggested. Confused
Re: 4K no spark, help? Sun, 06 February 2005 11:45 Go to previous messageGo to next message
yup, shorted wire... what about the wires from the points to the coil.. it's not shorting either inside or outside of the dizzy?
do you have 12V to the coil, and the -ve side only goes to the points?
to check if the coil is ok, take all the wires off the -ve side of coil, then attach a wire to the -ve aide of coil, touch it briefly to a ground (battery is good), when you break the connection, you will get a spark.
what you could do is to get an LED (with appropriate resistor) and connect it between power and the points. turn the motor over. if the LED flashes, then the points an it's circuit are working..
you may have a loose lead somewhere, you may have an internal failure of the coil or the condensor etc etc..
check each part one by one..
MR. 2
Parramatta
Re: 4K no spark, help? Sun, 06 February 2005 21:45 Go to previous messageGo to next message
funny that this is posted exsactly same has happened to me this weekend i have replaced the coil taken the plugs out and leads are brand new (almost) I can only think its the ignighter or wiring somewhere.
let me know what happenes
Hobart, Tasmania
Re: 4K no spark, help? Tue, 08 February 2005 11:02 Go to previous message
Fixed, faulty ballast resistor, and a crossed wire.
thanks guys
Cheers Kieran
Previous Topic:2tg electronic ignition
Next Topic:Celica 83 or 81 ?? why is there 2 diff...
Current Time: Sat Nov 21 00:13:26 UTC 2026
Total time taken to generate the page: 0.0052759647369385 seconds
