Classifieds » Engines, Accessories and other Mechanicals » $500 Turbo,manifold,wastegate from 18RG
91golux
mackay
icon14.gif   $500 Turbo,manifold,wastegate from 18RG Sun, 06 February 2005 11:56 Go to next message
Any one interested in a turbo set up for an 18rg twin cam.
Included is a to4 turbo, 42mm garrett wastegate and manifold.
It came out of a 91model hilux but will suit any thing with a 18RG.
Turbo needs a rebuild, as it is a bit smoky and leaks oil to the comp cover,every else in good condition.
$550.
Also ave a set of 440cc top feed injectors from a 3sgte
$150 ono
jeff 0407112741.http://forums.toymods.org.au/index.php?t=getfile&id=9599
Attachment: 18r.jpg
(Size: 48.08KB, Downloaded 454 time(s))
[Updated on: Thu, 10 February 2005 12:53]
91golux
mackay
Re: Turbo,manifold,wastegate from 18RG Mon, 07 February 2005 13:08 Go to previous messageGo to next message
JUST A QUICK UPDATE.
The turbo specs are as follows
.6 To4 comp cover with 3" inlet
.45 rotormaster turbine/.5 garrett also available
'H' trim comp wheel which i think is 55mm
'O' trim turbine wheel.
The center housing is oil cooled only
The wastegate is a origional 42mm garrett and the manifold is made from steam pipe.
This turbo setup wasn't made for extream Hp but it did make 120kw atw with 12psi boost with very conservative tuning.
I also have a standard 1ggte intercooler if any one is interested.
Price now $500 for all the turbo gear.
4 x 440cc 3sgte injectors now $100.
Steve M
Re: Turbo,manifold,wastegate from 18RG Wed, 09 February 2005 11:01 Go to previous messageGo to next message
Do those injectors fit straight into an 18RG fuel rail and STD intake manifold?
If so I may be intersted in buying them.
Steve M
Re: Turbo,manifold,wastegate from 18RG Wed, 09 February 2005 11:45 Go to previous messageGo to next message
I only just saw that you said 440cc 3sgte TOP FEED injectors.
I was under the impression that 3SGTE injectors were normally side feed. What are these from.
If they go into the 18RG rail and Manifold then I reckon I will buy them for that $100.
How are they condition wise? Need clean?
91golux
mackay
Re: Turbo,manifold,wastegate from 18RG Thu, 10 February 2005 12:41 Go to previous messageGo to next message
They are 440cc top feed injectors, as far as i know the 165gt4 uses top feed type. some one correct me if Im wrong.
They do fit the standard 18rg efi manifold (fuel rail)
The injectors work fine but i would recomend a clean.
I think $100 is a reasonable price.
Im sorry I cant post pictures of them as my pc is getting repaired and Im using a friends computer.
Steve M
Re: $500 Turbo,manifold,wastegate from 18RG Fri, 11 February 2005 04:24 Go to previous messageGo to next message
I just got PM'd from someone who gave me some info. You are indeed correct about the suitability of the injectors.
I am awaiting a response of advice on being able to use those injectors (ECU match ups and the like).
I am still interested and that price is fine, I just want to know more about how I could run them before I would purchase.
I hope you understand my situation.
If anyone else wants them then don't wait on my behalf.
Thankyou for your patience.
-Steve M
91golux
mackay
Re: $500 Turbo,manifold,wastegate from 18RG Fri, 11 February 2005 07:28 Go to previous messageGo to next message
turbo and gate still up for grabs
people100
Rocklea qld
Re: $500 Turbo,manifold,wastegate from 18RG Fri, 11 February 2005 10:26 Go to previous messageGo to next message
seperate the manifold???
91golux
mackay
Re: $500 Turbo,manifold,wastegate from 18RG Sat, 12 February 2005 12:46 Go to previous messageGo to next message
If you are after the manifold only, no problems.
What are you offering.
The turbo stud pattern is large T4 not T3.
people100
Rocklea qld
Re: $500 Turbo,manifold,wastegate from 18RG Sat, 12 February 2005 21:27 Go to previous messageGo to next message
i dont know what there worth...im just throwing things around at the moment...what do u want for it...i have a t04 and external waste gate that im using on my engine.
91golux
mackay
Re: $500 Turbo,manifold,wastegate from 18RG Sun, 13 February 2005 02:14 Go to previous messageGo to next message
Injector update
Im sorry for the wrong information but these injectors are actually from a 7mgte. Sorry for the wrong info but im selling for a friend and ive just found out the correct info. Open to offers !
people100
Rocklea qld
Re: $500 Turbo,manifold,wastegate from 18RG Sun, 13 February 2005 09:27 Go to previous messageGo to next message
7mgte and 3sgte are the same im pretty sure....can u find out about the manifold price for me asap please
people100
Rocklea qld
Re: $500 Turbo,manifold,wastegate from 18RG Mon, 14 February 2005 11:22 Go to previous messageGo to next message
any news on the manifold yet?
91golux
mackay
Re: $500 Turbo,manifold,wastegate from 18RG Mon, 14 February 2005 12:00 Go to previous messageGo to next message
People 100
Please check email.
people100
Rocklea qld
Re: $500 Turbo,manifold,wastegate from 18RG Wed, 16 February 2005 10:49 Go to previous messageGo to next message
sorry did not recieve an email...ill check again but didnt see one there so possibly pm me for better result
91golux
mackay
Re: $500 Turbo,manifold,wastegate from 18RG Wed, 16 February 2005 11:19 Go to previous messageGo to next message
People 100 Your offer sounds ok
pm me if still interested and i will sen you my bank details
people100
Rocklea qld
Re: $500 Turbo,manifold,wastegate from 18RG Wed, 16 February 2005 11:26 Go to previous messageGo to next message
pm replied
91golux
mackay
Re: $500 Turbo,manifold,wastegate from 18RG Fri, 18 February 2005 07:05 Go to previous message
Manifold SOLD
Turbo / Wastegate still for sale.
Previous Topic:ST185 GT4 halfcut leftovers plus AE86 LSD diff
Next Topic:RWD 4A-GTE engine conversion, w/everything. Suit AE86/AE71
Current Time: Sun Nov 22 01:54:46 UTC 2026
Total time taken to generate the page: 0.018790006637573 seconds
