Toymods » Tech & Conversions » Screwing with a 1G - what do these two screws do?
ra23celica
Screwing with a 1G - what do these two screws do? Sun, 06 February 2005 23:49 Go to next message
Excuse the dumb arse question, but I have found two screws in the intake system of my 1G-GZE. Both of these are under black rubber caps and accessible using a phillips head screwdriver.
One is in the AFM and the other is at the throttle body.
What do they do ? And
How do I play with them properly to tune/set-up my car.
Thanks for your help.
Mitch.
Fattony
Re: Screwing with a 1G - what do these two screws do? Mon, 07 February 2005 02:06 Go to previous messageGo to next message
One adjusts the spring on your afm, hence adjusting your mixtures and the other your im not so sure about though i do know it does make your idle change so it might be for some sort of bypass it has (/me shrugs) if you dont know wat these things are i really dont suggest that you play with them.
Cheers Adam
HyDrA
Adelaide, SA
Re: Screwing with a 1G - what do these two screws do? Mon, 07 February 2005 03:52 Go to previous messageGo to next message
afaik they're both designed to let air bypass something like the flap in the afm, or the throttle body butterfly.
The one on the AFM appears to be an adjustment to get the AFM flap to sit at the idle position by letting air pass by... I assume it'd also affect the mixture slightly.
ra23celica
Re: Screwing with a 1G - what do these two screws do? Mon, 07 February 2005 05:34 Go to previous message
Thanks Fattony and HyDrA,
Yes, I would agree that they both allow a controlable amount of air to bypass each of those components in turn and that mucking with them will stuff things up unless you know what you are doing.
I will try and hunt up some tuning information on them.
Mitch.
Previous Topic:iam doing up a corolla 2002 sedan auto got any seguestion ?
Next Topic:Clutch for my 1G
Current Time: Tue Oct 27 08:07:10 UTC 2026
Total time taken to generate the page: 0.10480999946594 seconds
