Toymods » Tech & Conversions » Heater Switch
Flebbert
Wagga
Heater Switch Mon, 07 February 2005 00:09 Go to next message
Ok, my heater in my Ma70 doesnt work. I have a new replacement tap but the switch doesnt work. The tap and switch are seperate...... Got tap of falcon. I have tested connection for signal and the light on my test light comes on when temp control is on cold or hot. Is this right....am guessing not. Help out be appreciated
phil
Flebbert
Wagga
Re: Heater Switch Tue, 08 February 2005 00:09 Go to previous messageGo to next message
bump
dingaling
tas
Re: Heater Switch Tue, 08 February 2005 03:14 Go to previous messageGo to next message
eh well if it's any help to u. my heaters don't work in my MA70 either. Well they do now sort of.
First thing i did was bypass the Valve in the engine bay at the firewall on the passenger side. That at least allowed hot coolant to flow into my heater core. But it still did not work, then i found out the heater switch (the climate control) was the other culprit, and by pushing the slider VERY hard to the right (hot side) that hot air would come out. Then as soon as i let it go, cold air would come out.
I haven't had any luck fixing the switch, so i buaght another one of manny, should be here soon. It could be a common MA70 problem, i'll rip down my bad switch and see what i can see, i reckon it's a common problem, most likely a bad solder or some kind of bad connection.
Flebbert
Wagga
Re: Heater Switch Tue, 08 February 2005 05:26 Go to previous message
Thanks for advice, i was thinking of getting the dash control unit of manny but i guess u beat me to it. This is what i know (if it helps you)
1. Heater tap on mine is dead
2. There is current going to my switch (next to tap)
3. Switch is broken as makes no difference sending it current or refusing it current
If u bypassed the tap in the engine bay, does that mean that there is a second tap controlling the flow of coolant?
Hope this helps u out some
Previous Topic:Late GenIII or GenIV 3S to install into Caldina?
Next Topic:W56, are they as strong as W58
Current Time: Sat Oct 24 22:21:30 UTC 2026
Total time taken to generate the page: 0.0040078163146973 seconds
