Toymods » Tech & Conversions » 1JZ Clutch Fan
Skip
icon2.gif  1JZ Clutch Fan Mon, 07 February 2005 08:05 Go to next message
Is it possible to unbolt the plastic fan from the fan clutch/hub assembly?
Re: 1JZ Clutch Fan Mon, 07 February 2005 08:33 Go to previous messageGo to next message
If you remove the fan from the 4 bolts, there are some bolts holding the fan itself on. Thats how mine was, cos I took it off to spray it.
BlackSupra
Re: 1JZ Clutch Fan Mon, 07 February 2005 08:39 Go to previous messageGo to next message
http://www.geocities.com/ifli4u/jza61thermos.jpg
The above is a 2jzge.
You will need about 8 washers to put under the nuts as the threads from the water pump studs arent long enough to tighten all the way down.
Skip
Re: 1JZ Clutch Fan Mon, 07 February 2005 09:25 Go to previous messageGo to next message
Thanks for that frank thats what I thought.
Blacksupra: I dont think you understood what i meant, im talking about clutch fan not thermofan.
Re: 1JZ Clutch Fan Mon, 07 February 2005 10:47 Go to previous messageGo to next message
I think he meant about removing the fan and fixing it so the pulley stays. Regardless, no problems Razz
BlackSupra
Re: 1JZ Clutch Fan Mon, 07 February 2005 11:09 Go to previous messageGo to next message
I thought it was a pretty clear explanation
Skip
Re: 1JZ Clutch Fan Mon, 07 February 2005 11:25 Go to previous messageGo to next message
hehe bit of confusion here i think, sorry BlackSupra I just looked at your picture of the thermofans and thought you had shot off in a different direction, didnt read your text to thoroughly my bad.
Anyway to clear this up once the fan assembly is removed from the pulley I then wish to seperate the plastic blade part from the hub/clutch/stubshaft. Possible or not?
Im not concerned with leaving the pulley on the engine but dismantiling the actual fan assembly.
Re: 1JZ Clutch Fan Mon, 07 February 2005 11:28 Go to previous messageGo to next message
Yep, thats what I said in my first post, there should just be some bolts holding the fan to the clutch/hub.
BlackSupra
Re: 1JZ Clutch Fan Tue, 08 February 2005 06:37 Go to previous messageGo to next message
It can be done yes.........but why?
got a broken plastic bit?
Skip
Re: 1JZ Clutch Fan Tue, 08 February 2005 08:53 Go to previous messageGo to next message
BlackSupra wrote on Tue, 08 February 2005 14:37
Bulls Eye
1 Fan has broken plastic bit, one has stuffed bearing Smile
Icarus
Emerald
Re: 1JZ Clutch Fan Wed, 09 February 2005 05:35 Go to previous message
Thanks for the info everyone, this was for my soarer. The two fans have been changed now so it's all good.
D
Previous Topic:Camber on AE92/93 SX
Next Topic:soarer headlight cleaning
Current Time: Wed Nov 18 19:26:05 UTC 2026
Total time taken to generate the page: 0.018878936767578 seconds
