Toymods » Tech & Conversions » 2tg electronic ignition
jesseT18
Castle Hill, Sydney
2tg electronic ignition Mon, 07 February 2005 08:20 Go to next message
i recently wired up all my electronic ignition to replace the old points setup
it all went well and wired up neatly, but for some reason it has no spark!
would anybody have a wireing diagram or something to help out?
the coil is getting power, and the ignitor has a good earth.
the plugs on the ignitor are as follows
16- blue and red wire to coil negative
15- red wire to coil positive
3- brown wire to dizzy
7- black wire to dizzy
thanks!! jesse
TA22-3SGTE
MACKAY
Re: 2tg electronic ignition Mon, 07 February 2005 11:28 Go to previous messageGo to next message
Your wires to the igniter are correct as long as brown from the dizy is positive to pin 3 , try reversing pin 3 & 7 connections also try clossing the air gap on the pickup .
Trevor
jesseT18
Castle Hill, Sydney
Re: 2tg electronic ignition Mon, 07 February 2005 21:13 Go to previous messageGo to next message
i tried swopping 3 and 7, still no spark, i am pretty sure they are the right way around because 3 and 7 have diffeent sized pins, they only fit on one way.
will try closing the air gap this arvo, and other ideas peoples?
it's the 2tgeu dizzy with the 2 black plastic boxes inside it, and the coil/ignitor are off a 3tgte (not standard) if that helps
jesseT18
Castle Hill, Sydney
Re: 2tg electronic ignition Tue, 08 February 2005 07:12 Go to previous messageGo to next message
air gap was about 0.1 so i opened it up to 0.3, still no spark...
[Updated on: Tue, 08 February 2005 09:05]
jesseT18
Castle Hill, Sydney
Re: 2tg electronic ignition Tue, 08 February 2005 08:58 Go to previous messageGo to next message
can anybody tell me if this is an internal ignitor distibutor?
http://img161.exs.cx/img161/8258/dizzy3eo.jpg
[Updated on: Tue, 08 February 2005 09:04]
t_temperley
Re: 2tg electronic ignition Tue, 08 February 2005 09:42 Go to previous messageGo to next message
yep, its the internal ignitor dizzy.
i ran mine with a bosch gt40, gave me no grief..
jesseT18
Castle Hill, Sydney
Re: 2tg electronic ignition Tue, 08 February 2005 09:44 Go to previous messageGo to next message
hmmm okay, would that be why im not getting any spark?
because i was trying to run it with a external ignitor...
and do i just run the + and - from the coil straight to the dizzy?
and coil off the 3tgte should still do the trick?
[Updated on: Tue, 08 February 2005 09:47]
TA22-3SGTE
MACKAY
Re: 2tg electronic ignition Tue, 08 February 2005 12:13 Go to previous message
Yes
Yes
Previous Topic:KE20 Master cyl??
Next Topic:4K no spark, help?
Current Time: Sat Nov 21 00:29:45 UTC 2026
Total time taken to generate the page: 0.0047969818115234 seconds
