Classifieds » Parts Wanted » 1JZ-GTE flywheel and other manual parts
Levin4Kevin
Sydeny
1JZ-GTE flywheel and other manual parts Mon, 07 February 2005 09:14 Go to next message
I'm after a flywheel for a 1JZ and possibly the pressure and clutch plate if near new. Also need a clutch pedal set up, including master cylinder. It's all for a MX83 Cressida and I believe the MA70 pedals are very similar.
Ta, Kevin
manmx83
Re: 1JZ-GTE flywheel and other manual parts Mon, 07 February 2005 15:54 Go to previous messageGo to next message
Hi Kevin,I fitted a jza70 clutch pedal to my mx83 but it was a pain.If you go to the trouble of making a paper template of the size and angle of the mounting area and shape from the interior with a reference to horizontal you will note that a jza70 clutch set up wont mount vertical,it leans toward the brake booster.
Armed with this template you could go shopping at a toyota Smile wreckers.I noted a stoty of one done with a hilux or hiace part.FWIW. Good luck mate,Pete.
The Count
Re: 1JZ-GTE flywheel and other manual parts Tue, 08 February 2005 02:33 Go to previous messageGo to next message
try toyota their not that expensive
Levin4Kevin
Sydeny
Re: 1JZ-GTE flywheel and other manual parts Sat, 12 February 2005 21:04 Go to previous message
Have now been told that a non turbo 2J Flywheel and clutch will be as good if not better, so if anyone can help please reply or ring on 0413 135472.
Ta, Kevin
Previous Topic:WTB: Ignitor for 1JZGTE
Next Topic:eoi peewee,dexter etc around 80cc syd
Current Time: Tue Oct 27 03:59:19 UTC 2026
Total time taken to generate the page: 0.10181403160095 seconds
