Toymods » Tech & Conversions » bolt gze charger onto ge
Ribbo
Northern Beaches
bolt gze charger onto ge Mon, 28 October 2002 08:44 Go to next message
What would be required for me to bolt the gze supercharger onto my bluetop ge? it has 7rib block but no idea what internals.
I also have a microtech digi 1 so changing computers won't be needed.
What bits from the gze would I need?
Would the ge hold up under the small amounts of boost the gze charger puts out?
Its into a ae86 too.
Thanx
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: bolt gze charger onto ge Mon, 28 October 2002 09:32 Go to previous messageGo to next message
Freak i thought a bluetop only had a 3 rib block?? it also is spose to have a smaller crank and journals (spelling?), i think the journals are 16mm compared to 20mm in a 7 rib....i could be wrong, but that's what i thought....
the red and black 88kw one (original aw11 ge) has a 7 rib block and the bigger internals...
you would need the complete ze inlet setup, as without making new s/c mounts it will not fit under the ge inlet manifold
(it needs to mount about 2 1/2 - 3" lower to fit under a ge inlet manifold)..
the ze injectors would be a good idea...
people have turbo'd the ge, but i beleive it is not too reliable after 5psi...(going on what i have read on other forums).
[Updated on: Mon, 28 October 2002 09:33]
Ribbo
Northern Beaches
Re: bolt gze charger onto ge Mon, 28 October 2002 21:46 Go to previous messageGo to next message
cool thanx for that, didn't realise u would need all the ze inlet too.
To fit ze in the ae86 don't u need to modify the s/c mounts anyway to clear the alternator?
Im actually not sure what "colour" my ge is cos the rocker paint has been taken off, it may be the black one ur talking about. Its a bigport head, tvis inlet but has a 7rib block. Would this have the bigger internals?
Im probably just better off getting a ze hehe
feral4mr2
Bundaberg, Qld.
Re: bolt gze charger onto ge Mon, 28 October 2002 22:14 Go to previous messageGo to next message
Freak oh, yeah, the alternator...you would need to get it's mounts of a ze too, and mount it on the exhaust side, above the a/c compressor...
well my old ge is a 7 rib block, bigport head, t-vis. it has the bigger internals, i beleive the same as a s/c block...but, it has highter compression pistons compared to a s/c block and there not forged or coated, i think around 9.6:1 ?? cant remember on that one..(the early ze is 8.0:1, and later 8.9:1)
yes i think just getting a ze would probably be a better idea in the long run, it's built 4 boost...
Ribbo
Northern Beaches
Re: bolt gze charger onto ge Tue, 29 October 2002 06:13 Go to previous message
yeah im not sure if my pistons would be the 100kw or the 86kw ones, it doesn't seem to rev as happily as my old ae82 but has lots more torque lower in revs and it is much quicker.
I don't have a/c Smile
all so expensive and I don't have money hehe
Previous Topic:RA28 Front disc upgrade help!!
Next Topic:jzx90 into mx83
Current Time: Sun Nov 22 20:05:34 UTC 2026
Total time taken to generate the page: 0.014430999755859 seconds
