Toymods » Tech & Conversions » Help: decent thermofan brands?
V8_MA61
icon4.gif  Help: decent thermofan brands? Mon, 07 February 2005 12:09 Go to next message
Hi guys, after finding my GT4 fans dont fit, im in the hunt for a new one.
It needs to be 14" and flow a shiteload of air - it has to pull through a 70mm thick radiator.
Ive seen a few brands with decent looking specs:
Tripac
Davies Craig (had poor cfm and life expectency tho Confused ?)
Flex-a-lite
CI Electric
Proflow
now the one with the most impressive specs was the Pro-Flow, but i cant seem to find the dimensions of it anywhere on the web. It is for sale on Ebay. I'm wondering - is this a shit brand or are they good?
Ive spent a lot on this motor and i cant afford to let it boil -
hence im looking at a NEW fan which needs to flow highly.
Any help greatly appreciated.
Blake
Re: Help: decent thermofan brands? Mon, 07 February 2005 14:41 Go to previous messageGo to next message
I wouldnt use anything but AU/EL Ford thermo's.
They move a dickload of air.
Re: Help: decent thermofan brands? Mon, 07 February 2005 14:55 Go to previous messageGo to next message
Dickload of air yes, but not terribly compact.
Re: Help: decent thermofan brands? Mon, 07 February 2005 15:03 Go to previous messageGo to next message
Bah, its between 80 and 85mm depth you need.
With a 70mm radiator, you should only need 2 5mm fans.
fatboy
January 2005
Re: Help: decent thermofan brands? Tue, 08 February 2005 08:10 Go to previous messageGo to next message
ensure that you've got a suitable fan shroud. sounds like a waste and can be ugly but makes incredible difference. it makes sure that air is pushed only through radiator not everywhere else.
Re: Help: decent thermofan brands? Tue, 08 February 2005 08:17 Go to previous messageGo to next message
permacool brand?
V8_MA61
Re: Help: decent thermofan brands? Tue, 08 February 2005 13:00 Go to previous messageGo to next message
one constructive reply, thanks oldcorollas.
SPAL look pretty good also. fucken expensive tho!
AU thermos are 1: too deep for my room available, 2: shit in comparison to a single 16" volvo fan with a bit smaller shroud.
[Updated on: Wed, 09 February 2005 15:19]
Re: Help: decent thermofan brands? Tue, 08 February 2005 13:24 Go to previous messageGo to next message
V8_MA61 wrote on Tue, 08 February 2005 21:00
AU thermos are 1: too wide for my radiator, 2: too deep for my room available, 3: shit in comparison to a single 16" volvo fan with a bit smaller shroud.
Oh yeah, they're crap Rolling Eyes Is your radiator narrower (width wise, not thickness obviously) than an MA61 one?
Re: Help: decent thermofan brands? Tue, 08 February 2005 13:50 Go to previous messageGo to next message
regarding shrouds- the advice i got from western suburbs radiators (who did my 3-core in the RA40 was to ensure the shroud at hte rear covered the back of the radiator so the fan(s) only pulled air thru the core - not from open surrounds.
wilbo and norbie can attest to the abilty of my radiator to take in a lot of heat (.. say from a red hot turbo and manifold) and pull it out the core in a gale of hot, acrid air Wink. The shroud is only 30mm or so off the back of the rad but completely encloses it and has hi-temp foam/rubber to improve sealing.
fwiw: some newish merc's have two fans infront of the rad - the shroud i saw was integral to the grill (which was attached to the bonnet) - they looked very thin.
V8_MA61
Re: Help: decent thermofan brands? Wed, 09 February 2005 15:05 Go to previous messageGo to next message
justcallmefrank wrote on Tue, 08 February 2005 23:24
Its actually wider than an ma61 radiator. And yes they are shit in comparison to the volvo one. I'm yet to get its dimensions, but im told it is too deep for what i need. Sad
V8_MA61
Re: Help: decent thermofan brands? Wed, 09 February 2005 15:07 Go to previous messageGo to next message
thechuckster wrote on Tue, 08 February 2005 23:50
I'd be mounting the fans flush to the radiator, as i cannot make a shroud, my choice of radiators has ment i need to make them flush and least deep possible
Re: Help: decent thermofan brands? Wed, 09 February 2005 15:08 Go to previous messageGo to next message
And you're basing this off hard facts or hearsay? Rolling Eyes
Ok, so if your radiator is WIDER than an MA61 one, and the AU thermos fit fine on an MA61 radiator, what credibility does that give any of your info?
V8_MA61
Re: Help: decent thermofan brands? Wed, 09 February 2005 15:14 Go to previous messageGo to next message
justcallmefrank wrote on Thu, 10 February 2005 01:08
I already said the AU fans are too deep didnt i? And the volvo one ive seen (16" it is) and experienced testing from memory is as deep or deeper, but it sucks a shitload more air.
The example it was used on was a hot 351 in an XY falcon ute. The AU fans werent keeping it cool enough in the 40"+ heat, and then they were exchanged for this volvo one, they never had another problem. Both were adapted properly to fit nicely on the radiator
Re: Help: decent thermofan brands? Wed, 09 February 2005 15:16 Go to previous messageGo to next message
You said it was too wide for your radiator, hence my question. Neutral
Anyways, I'm over it, it's like http://users.bigpond.net.au/justcallmefrank/mur.gif
V8_MA61
Re: Help: decent thermofan brands? Wed, 09 February 2005 15:17 Go to previous message
justcallmefrank wrote on Thu, 10 February 2005 01:16
Too deep i mean.
Previous Topic:reed switch fix for 20V in CS Limited
Next Topic:1GGS
Current Time: Sun Oct 18 17:53:48 UTC 2026
Total time taken to generate the page: 0.090147018432617 seconds
