Toymods » Tech & Conversions » ra 23 head unit installation
munki
Gold Coast
ra 23 head unit installation Mon, 28 October 2002 12:19 Go to next message
Hey people im new to the forums and i just wanna ask a couple of questions for people who have these cars.
Firstly I cannot find a dedicated power (POSITIVE +) anywhere. There are a few on the thingy where the blinkers, acc and horn connect (whatever it is called) and there would probably be one on the clock the wireing relay might be a bit weak tho. Splicing a wire would be annoying but i guess i have to. Anyone who has this car or similiar what is the best thing to do?
Also do any of you guys/gals have pictures of a standard din unit in the celica? what sort of things did you have to do? I'm able to do this all myself but it is easier with someone telling me all the tricks n stuff, saves me learning, and swearing
Daniel
Dylo
Re: ra 23 head unit installation Mon, 28 October 2002 14:09 Go to previous messageGo to next message
mate its easy as!
if you want a permanent wire, tap out of the brake lights fuse, b4 the fuse in the fuse box area.
do the same if you need an ACC signal too.
The easiest way to get it mounted nicely is to get rid of the old plastic shit, and make a piece of ply or something that goes down like the old one did, and cut the correct hole in it for the deck, and the demister switch too.
ra23celicachick
Mornington Peninsula
Re: ra 23 head unit installation Mon, 28 October 2002 21:54 Go to previous messageGo to next message
Don't go near the break light fuse! That's what's been done on mine and everytime I put my foot on the break when I'm running my sub and amp the sterio cuts out. It would be better to run it off an inline fuse I've been told to avoid this problem.
willwal98
Toowoomba
Re: ra 23 head unit installation Mon, 28 October 2002 23:28 Go to previous messageGo to next message
it's best to run a wire straight to the battery for your permanent +12v.
munki
Gold Coast
Re: ra 23 head unit installation Fri, 01 November 2002 09:47 Go to previous messageGo to next message
ra23celicachick wrote on Tue, 29 October 2002 07:54
hehehe yeah thats what i wanna avoid... to much current through the relay. I wouldnt be suprised if the brake lights cut out too. thenks for the help people, i thought there might have been an easy way but oh well...
direct line to battery for me...
thanks daniel
CamZH
Toodyay, WA
Re: ra 23 head unit installation Sat, 02 November 2002 05:13 Go to previous messageGo to next message
Hey Guys,
I put a cd player in the normal console in a RA28 with out too many probs, see the pic.
I fixed the basket to the underside of the dash where there is a pit of metal, i used some green plugs (rawl plugs) as spacers and it worked sweet.
I got my permanent power from the fuse box, but i was only running the head unit, no amp. This worked fine for me.
If i was running an amp i'd run a bigger (4mm min) from the battery to the amp, but you can power the head from the fuse box.
I got the acc power from the old radio loom.
I havent done any of this to the new RA28 as it has A/C and the head unit wont fit! so i'll have to make a custom center console...
on second thoughts i cant attach the pic cos the option isnt there!! wtf?? does someone want to host if for me??
CamZH
Bugman
Re: ra 23 head unit installation Sat, 02 November 2002 05:52 Go to previous message
here is the pic cam was referring to.
http://members.optushome.com.au/1977celica/CamZH/japstang5.jpg
[Updated on: Sat, 02 November 2002 05:53]
Previous Topic:A340E Auto Cressida Transmission & 1JZ-GTE
Next Topic:1UZFE-twin turbo queries
Current Time: Mon Oct 26 08:42:17 UTC 2026
Total time taken to generate the page: 0.0051579475402832 seconds
