Toymods » Tech & Conversions » fabbed intake manifolds
RWDboy
fabbed intake manifolds Mon, 28 October 2002 12:27 Go to next message
I'm trying to fit two solex carbs on my plain ol' 2T engine, and I'm pretty sure I need a fabricated intake manifold for it - the 2T-G manifold allegedly doesn't line up. I'm wondering what kind of cost I should be looking at for that kind of thing. I know it's possible to convert to a 2T-G, but I'm not sure which is cheaper.
I know that a 2T-G can produce more power than the OHV unit, but it's not a great deal more and I have the carbies already anyway. The standard manifold on the 2T-G is pretty short, and longer is usually better, that's why I'm looking at a fabbed one for the 2T.
Anyone got an idea how much this kind of thing will cost, (or who can do it in SA)???
Purple_Beasty
New Zealand
icon14.gif  Re: fabbed intake manifolds Mon, 28 October 2002 12:50 Go to previous messageGo to next message
Had a mate who had an adaptor plate made up to mount 2T carbs to his 2TG, so I dont see why is wouldn't work in reverse. From memory the port spacings are pretty much identical, just the bolt holes that are different.
Re: fabbed intake manifolds Mon, 28 October 2002 12:57 Go to previous messageGo to next message
FWDboy wrote on Mon, 28 October 2002 22:27
I don't know either, but I do know fabrication work can get expensive quickly (unless you can do it yourself), while 2T-G's can be had cheaply if you look around.
Longer manifolds tend to produce better bottom-end torque, while short manifolds are good for top-end power and sharp throttle response.
Grega
melbourne.victoria.austra...
Re: fabbed intake manifolds Mon, 28 October 2002 13:16 Go to previous messageGo to next message
the ports will line up its the bolt holes that don't - also the water thingo in the middle of the 2T will need to be welded up in your inlet manifold...
take it to someone with a tig, get "ears" welded on it where you need the new bolt holes, and, then re-tap new holes. simpler that way - also make sure you get the thing re-finished after you're done - as when they TIG it they have to heat it up and there is a good chance it will warp.
RWDboy
Re: fabbed intake manifolds Mon, 28 October 2002 13:18 Go to previous messageGo to next message
So what kind of price would I be looking at to get the 2T-G manifold modified? How strong is that sort of set up, because this engine will take a fair bit of punishment?
RWDboy
Re: fabbed intake manifolds Mon, 28 October 2002 13:59 Go to previous messageGo to next message
Oh and how large diameter are the intake manifold ports on a 2T-G manifold?
Grega
Re: fabbed intake manifolds Mon, 28 October 2002 16:59 Go to previous message
it cost me $35 to have the 2TGEU manifold modified.
i think the ports are 25mm from memory (only small)
Previous Topic:ta22 dumped over 17" wheels
Next Topic:Automatic Transmission Diagnosis
Current Time: Thu Nov 19 12:00:59 UTC 2026
Total time taken to generate the page: 0.0059340000152588 seconds
