Toymods » Tech & Conversions » quick query: size of bolt attaching pulsation dampener to 5ME fuel rail
quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 04:12 Go to next message
hi folks,
can anyone advise on the size of the huge nut/bolt-head that attaches the fuel pulsation dampener on the 5ME fuel rail?
it's bigger than 21mm (largest open-ended spanner i own) and the largest i can find at a hardware store (i work in the brisbane CBD so my only choice is a mitre10) is a 22mm.
will this fit? (or have i bought yet another nearly-useless tool)
i was nearly at the point where i attack it with my stilson pipe wrench but the head on it's too fat Wink
tia,
charles.
STR8 2.8
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 04:16 Go to previous messageGo to next message
its bound to be a 22mm as toyota only have set sizes in use. and 21mm is not one of them.
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 04:18 Go to previous messageGo to next message
Just use an adjustable and a hammer.
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 04:24 Go to previous messageGo to next message
CrUZsida wrote on Tue, 08 February 2005 14:18
if this 22mm doesn't fit then this is option 2. Laughing
wilbo666
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 06:37 Go to previous messageGo to next message
I'll check when I get home Smile Btw if you get stuck I have spanners upto 32mm.... Smile
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 08:18 Go to previous messageGo to next message
the bastards are too thin to use an adjustable spanner most times Sad stupid dampers Razz
wilbo666
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 08:52 Go to previous messageGo to next message
22mm is the answer. Smile
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 09:00 Go to previous messageGo to next message
I've always used an adjustable.
Never had any probs.
Re: quick query: size of bolt attaching pulsation dampener to 5ME fuel rail Tue, 08 February 2005 14:04 Go to previous message
the copper washers have been crushed too many times - i only had new washers for the fuel filter - hence the need for application of considerable effort.
my adjustable spanner came from supacrap so any application of torque on it makes it jam open. And i have an awful feeling that my expensive adjustable vicegrips (which would have done the job) got recycled in the post-renovation cleanup 'cause that's when i last saw them ;(
anyway, problem solved - expensive 22mm spanner 1, damper 0
the next person to open the engine up will probably want to replace it (or if they're smart - replace the engine with something like 1jz or 1uz)
Previous Topic:reusing a metal headgasket???
Next Topic:2tgeu redline???
Current Time: Sat Oct 17 13:35:51 UTC 2026
Total time taken to generate the page: 0.014181852340698 seconds
