Toymods » Tech & Conversions » 1JZ powersteer pump is noisy
cressida_1jz
On Probation
1JZ powersteer pump is noisy Tue, 08 February 2005 12:04 Go to next message
I just got my Cressida back from the mechanic who did the conversion and the p/s pump is noisy and carries on.Do they have a common problem with them?
Endless
Re: 1JZ powersteer pump is noisy Tue, 08 February 2005 14:14 Go to previous messageGo to next message
My power steering was a bit noisy when i first got the supra , but it just needed the fluid topped up ... lucky i guess
peeack
Re: 1JZ powersteer pump is noisy Tue, 08 February 2005 14:34 Go to previous messageGo to next message
Yeah, the 1j power steering pumps arn't much chop. At low RPM mine's harder to turn than a car without power steering. At any rate, check your fluid levels (although I assume they'd be good considering you just got it back from a mechanic) or find out about replacing it with one from a different engine? (I'd like to know if this is possible also)
Re: 1JZ powersteer pump is noisy Tue, 08 February 2005 14:53 Go to previous messageGo to next message
I can't see it being any different to the GA70 one on my car. Providing it has fluid it shouldn't be noisy as well. As for effort, make sure the vacuum lines are properly set up, mine is light as to turn at parking speeds.
lumpy
Adelaide, SA
Re: 1JZ powersteer pump is noisy Tue, 08 February 2005 22:46 Go to previous messageGo to next message
I had a few problems with the 1jz p/s pump - the first one the front bearing went and scored the shaft, and the second one (2nd hand) was always pretty noisy too. Make sure that it's been bled properly for a start - that can cause the whirring noise when you turn and low speed.
KOFFEE-BLACK
Re: 1JZ powersteer pump is noisy Tue, 08 February 2005 22:52 Go to previous messageGo to next message
lumpy wrote on Wed, 09 February 2005 09:46
Exactly like mine, its getting refurbished as we speak. Mine also was hard to turn at low rpm.
Driftspec
Re: 1JZ powersteer pump is noisy Tue, 08 February 2005 23:12 Go to previous messageGo to next message
KOFFEE-BLACK wrote on Wed, 09 February 2005 09:52
In the end it ended up being that all the seals on the second P/S pump (I own Lumpy's old car) were buggered and air was getting into the system on load staving it of oil. This had caused wear on the pump internally.
Had the pump rebuilt with new parts and got all the old hoses replaced at the same time and its as good as new.
It was not a cheapest option but was worth it, as it is brand new now.
Re: 1JZ powersteer pump is noisy Wed, 09 February 2005 06:45 Go to previous messageGo to next message
How much did it cost you to rebuild the pump if you don't mind me asking?
Driftspec
Re: 1JZ powersteer pump is noisy Wed, 09 February 2005 08:30 Go to previous messageGo to next message
$566.80 to be exact Smile
Overview of the job was "Seals & O'rings hard, Pump internals badly damaged"
So basically it involved,
- New bearing kit
- New Pump Seal Kit
- New Pump element
- misc parts (eg washers, clamps, fluid (transmax) etc)
- Labour (I am in the wrong trade)
I asked them to replace all the hoses at the same time
Basically I could have sourced another one second hand and had it installed cheaply, but 2 had already died so I was not taking the chance again.
Power steering system is now like new.
Re: 1JZ powersteer pump is noisy Wed, 09 February 2005 10:27 Go to previous messageGo to next message
Ouch!
I think I'll just put up with my noisy pump for now. It works. Smile
Driftspec
Re: 1JZ powersteer pump is noisy Wed, 09 February 2005 10:39 Go to previous messageGo to next message
hehe
I tried to as long as I could but it was just so loud and made the worst noise that I had to get it fixed! Very Happy
Jag7799
Re: 1JZ powersteer pump is noisy Wed, 09 February 2005 11:17 Go to previous messageGo to next message
mine used to make noise when I 1st got it back
I was told it could be air bubbles in the lines from the conversion.
got quiter and quiter over time
mine makes a big squeel when car starts and now its fine.
..J..
opening a can of whoop ass
Re: 1JZ powersteer pump is noisy Thu, 10 February 2005 00:45 Go to previous messageGo to next message
check the fluid level first. it may be air bubble
drive it for a few weeks if still no good get one from a wreckers. i got one from sss in sydney, cost $150 cash. chepaer than rebuild.
cressida_1jz
On Probation
Re: 1JZ powersteer pump is noisy Thu, 10 February 2005 12:59 Go to previous messageGo to next message
the power steer cut out on me today as i was flying into a corner,i shit myself.Thanx for the help guys,the motor has 6 months warranty on it i found out today so im sending the cressy back for a pump rebuild....
KOFFEE-BLACK
Re: 1JZ powersteer pump is noisy Thu, 10 February 2005 23:58 Go to previous message
Well, I got my bill back yesterday, was surprisingly a great price, fully rebuilt, by Terry Sheilds Toyota, for $240! Now its 100%!
Previous Topic:MON of the 98RON fuels?
Next Topic:Jay Car kit...rev limiter and gear shift light...need info on igntion type!
Current Time: Wed Nov 25 23:07:20 UTC 2026
Total time taken to generate the page: 0.0068359375 seconds
