Toymods » Tech & Conversions » 4AGE piston differences
ae86trueno
4AGE piston differences Tue, 29 October 2002 01:02 Go to next message
This is mainly for my general knowledge but i hope someone out there (Toby/Bill) has seen a few more 4AGE intrenals, can fill in the gaps.
Ok its my understanding so far that these are defineately 86KW pistons, dished centre accounts for lower compression??
http://us.f1.yahoofs.com/users/fdc6ad13/bc/My+Photos/86KW.jpg?bcgFX59A8OaTmT0G
Its the next two pistons that im confused about
First is the ACL Replacemant 100Kw. no dishing, flat in centre higher compression??
http://us.f1.yahoofs.com/users/fdc6ad13/bc/My+Photos/100KWACL.jpg?bcgFX59A6WG8.or2
The next one is the one i just pulled out of my car, 100KW toyota with a raised centre (presumably higher compression again)
http://us.f1.yahoofs.com/users/fdc6ad13/bc/My+Photos/100KWtoyota.jpg?bcgFX59APvMw7CwM
Now to my question, is the ACL replacement 100KW piston that way to save manufacturing costs or is there are 3 types of pistons???
Ben
AE86 Trueno 4AGE
dr_goolz
Central Coast
Re: 4AGE piston differences Tue, 29 October 2002 09:54 Go to previous messageGo to next message
Manufacturing cost would have been the main consideration behind the design of the top of the ACL piston.
Although I’m sure ACL has considered the compression ratio in their design, and should be no difference between them.
Although Toyota isn’t stupid, and does a lot of engineering research, So the raised center may be beneficial in some way.
TE72_Turbo
Re: 4AGE piston differences Tue, 29 October 2002 10:55 Go to previous messageGo to next message
The factory toyota 86kw pistons I have here dont look like that top picture. The valve reliefs are not as deep, which would maybe suggest that the deck height of the whole piston top might be lower to drop compression rather??
kingmick
Banned by his request
moved to tamworth
Re: 4AGE piston differences Tue, 29 October 2002 11:34 Go to previous messageGo to next message
the first is a 8-1{early gze} piston the second is 8.9-1{late gze} and the third is a 100kw 9.4 or 10.3 or something like that.
there is 4 diffrent pistons from memory, been awhile since i looked into it. i have had every one of them at times and im pretty sure the above is right. cc them then youll know for sure.
mick
ae86trueno
Re: 4AGE piston differences Tue, 29 October 2002 11:52 Go to previous messageGo to next message
Just a note, the deck height (the distance from the top of the Pin to the very outside edge of the piston anyway)is the same for all the pistons, The toyota one is taller overall due to the raised centre, as for being GZE pistons they are not marketed as that so ????
Ben
AE86 trueno 4AGE
Johnny
Sydney, OZ
Re: 4AGE piston differences Tue, 29 October 2002 22:49 Go to previous messageGo to next message
Ben,
The top piston does look very similar to an FE piston. It's hard to see the valve angle to be 100% sure from the photo, but also I really haven't see a set of 86Kw pistons either. The only differences I can say is that there's more "raised" area's than on an OEM FE piston.
The second ones are 100kw replacement for sure, I have a set of forgies that look Identical to that in two engines, one a 4age, the other is my 7AFE, and they sure do have a high comp that standard, but that's due to the piston heights. see pic belowhttp://members.ozemail.com.au/~johnek/pistons.jpg
Grega
melbourne.victoria.austra...
Re: 4AGE piston differences Wed, 30 October 2002 20:00 Go to previous messageGo to next message
i have a set of 86kw pistons at home i'll clean one up and photo it then post it up if you guys want? let me know..
Johnny
Sydney, OZ
Re: 4AGE piston differences Wed, 30 October 2002 22:49 Go to previous messageGo to next message
Please do.
Grega
Re: 4AGE piston differences Thu, 31 October 2002 00:20 Go to previous messageGo to next message
okies will do tonite.
Grega
Re: 4AGE piston differences Thu, 31 October 2002 06:00 Go to previous messageGo to next message
okies here we go :
http://www.vncommodore.com/images/86kw1.jpg
there is a U stamped on there, with a 1 also stamped on there
http://www.vncommodore.com/images/86kw2.jpg
the numbers on it say 16020
http://www.vncommodore.com/images/86kw3.jpg
another pic top down
these are from an 86kw RWD config motor.
any issues let me know
TE72_Turbo
Re: 4AGE piston differences Thu, 31 October 2002 11:08 Go to previous messageGo to next message
Yup, that looks just like the 86kw FWD ones I have. I think the number stamped on top is the size indicator. Toyota use different sizes if neccessary in individual cylinders to match the tolerances for that particular bore perfectly.
Grega
Re: 4AGE piston differences Thu, 31 October 2002 19:44 Go to previous messageGo to next message
yeah unfortunately these pistons are a bit beyond it...
ae86trueno
Re: 4AGE piston differences Fri, 01 November 2002 06:06 Go to previous messageGo to next message
Well at lease you were able to show us they are very simiar to the ACL equivelant
Ben
AE86 Trueno 4AGE
Johnny
Sydney, OZ
Re: 4AGE piston differences Fri, 01 November 2002 15:48 Go to previous messageGo to next message
Thanks, Grega
You can clearly see the 100Kw would have a lot more comp, if the combustion chamber of the 100Kw head isn't different to the 86Kw....
Grega
Re: 4AGE piston differences Fri, 01 November 2002 20:49 Go to previous messageGo to next message
where is bill.......we need bills thoughts on this... Smile
kingmick
moved to tamworth
Re: 4AGE piston differences Sat, 02 November 2002 04:16 Go to previous message
ill have a look at all the types i have which is all 4ag,4agze and will tell you guys on monday night or so.
mick
Previous Topic:1UZ factory management mapping
Next Topic:2JZ-GE clutch - what can it take?
Current Time: Thu Oct 29 15:52:59 UTC 2026
Total time taken to generate the page: 0.0068380832672119 seconds
