Toymods » Tech & Conversions » 1G-GTE Is this all that's needed ?
dispatcher
Malaysia,Kuala Lumpur
1G-GTE Is this all that's needed ? Thu, 10 February 2005 21:37 Go to next message
Hello all, just did a check and wanted to confirm are these all I need to change the timing belt for the 1G-GTE ?
Belt part no 3568 - 79035
Rear Oil Seal TC12660VI
Tensioner 54TB058B05
If these are the parts,can someone please confirm the part numbers,if I'm missing a few, please advise part name and number.
Cheers all
Fattony
Re: 1G-GTE Is this all that's needed ? Thu, 10 February 2005 23:04 Go to previous messageGo to next message
Why would you need to change the rear main seal when doing your timing belt?
RG65
Re: 1G-GTE Is this all that's needed ? Fri, 11 February 2005 03:37 Go to previous messageGo to next message
I am pretty sure the tensioner number starts with a 52 not 54, all my gear is from the gen 3, i dont know that they are diffrent. the belt number is T865. unless you are changing the clutch or the rmos is leaking i would leave it alone. the timing cover (front balancer) seal number i dont remember, sorry. while you have everything off the front of the motor you could change the oil pump seal and cam shaft seals.
Fattony
Re: 1G-GTE Is this all that's needed ? Fri, 11 February 2005 06:11 Go to previous messageGo to next message
I got a gen 1 sitting there that i might be able to get part numbers off, the motor is in peices with cam gears off so yes they are accessable
Cheers Adam
badboybubby
On Probation
Re: 1G-GTE Is this all that's needed ? Fri, 11 February 2005 10:56 Go to previous messageGo to next message
Thatd be a great help Very Happy
dispatcher
Re: 1G-GTE Is this all that's needed ? Fri, 11 February 2005 14:28 Go to previous messageGo to next message
OK..was just trying to cover all angles here...
So no need to change seals..if they're not leaking fine.
So it's just the belt - If anyone can correct the part number great.Tensioner - again correct part number needed.Camshaft seals..part number ?
Did I miss anything else ? Oh it's a Gen 3
RG65
Re: 1G-GTE Is this all that's needed ? Mon, 14 February 2005 12:30 Go to previous messageGo to next message
the tensioner number is 52tb058b05. if you go to a cbc (consolidated bearing company) dealer and give them the t865 number they will give you the right belt, you can also get the tensioner from there. i will send the cam seal number to you from work tomorrow.
badboybubby
On Probation
Re: 1G-GTE Is this all that's needed ? Mon, 14 February 2005 12:43 Go to previous messageGo to next message
Cool thanks heaps geez is there an easy way to get the oil pump pulley off Mad
[Updated on: Tue, 15 February 2005 05:49]
dispatcher
Re: 1G-GTE Is this all that's needed ? Mon, 14 February 2005 13:54 Go to previous messageGo to next message
Thanks guys...RG65..appreciate your help.
stradlater
Arthurs Creek, Victoria
Re: 1G-GTE Is this all that's needed ? Tue, 15 February 2005 06:26 Go to previous messageGo to next message
I know you've probably already decided to do this, but for heavens sake DON'T miss the cam seals, because they are prone to leaking if you dont' change them.
dispatcher
Re: 1G-GTE Is this all that's needed ? Tue, 15 February 2005 09:08 Go to previous messageGo to next message
Thanks so much guys..I appreciate all the advise...
just to recap...
Timing belt
tensioner
Cam Seals.
Did i miss anything ?
stradlater
Re: 1G-GTE Is this all that's needed ? Tue, 15 February 2005 22:55 Go to previous messageGo to next message
Front and rear main seals???
stradlater
Spigot Bearing? Sump bolt washer
Fattony
Re: 1G-GTE Is this all that's needed ? Tue, 15 February 2005 23:17 Go to previous messageGo to next message
You might aswell do your head gasket while your at it LOL
stradlater
Re: 1G-GTE Is this all that's needed ? Tue, 15 February 2005 23:56 Go to previous messageGo to next message
Bah.. Take it from experience, you need those bits replaced, or they cause problems.
But, if your in there, the bottom end bearings aren't that hard to get to.
badboybubby
On Probation
Re: 1G-GTE Is this all that's needed ? Wed, 16 February 2005 03:30 Go to previous message
Anyone got the idler part number ?
Previous Topic:Battery box question
Next Topic:Bottom Feed Injectors (Hi Flow Methanol) Advice needed
Current Time: Mon Oct 19 23:33:42 UTC 2026
Total time taken to generate the page: 0.13274598121643 seconds
