Toymods » Tech & Conversions » oil pressure gauge info
SIKTA22
oil pressure gauge info Fri, 11 February 2005 11:18 Go to next message
A few days ago i just bought myself a speco oil pressure gauge (mechanical) for my 2TG, inside the box it comes with nuts and bolts etc but where im stuck is, the bolt that comes in the box for you to install onto the block doesnt fit so ive been looking for an alternative at hardware stores, plumber stores to find something similar but with no luck.. any suggestions? Confused
thanks Smile
people100
Rocklea qld
Re: oil pressure gauge info Fri, 11 February 2005 11:24 Go to previous messageGo to next message
i had the same with mine...my fitting for the block was a holden size....i just found another at a wrecker as i couldnt find any at shops.
styler
Re: oil pressure gauge info Fri, 11 February 2005 16:20 Go to previous messageGo to next message
ahhhh, yes it happens to a lot of people
"it doesnt fit" which is common with gauge
senders. the fitting is probably designed for
the most common fit, adapters are avaliable
from speco to adapt your fitting to your block
whatever you do dont force the wrong thread in lol
http://www.speco.com.au/gauges_ad.html
usually repco can sort you out Very Happy
SIKTA22
Re: oil pressure gauge info Fri, 11 February 2005 23:13 Go to previous messageGo to next message
thanks guys, yeah well it shouldnt be that hard to find an adapter i hope, might go back to repco where i bought it from and see what they can do..
cheers.
Robbo85
January 2005
Re: oil pressure gauge info Sun, 13 February 2005 06:14 Go to previous messageGo to next message
dude go to pirtek. they have stuff like that.
wagonist
Toymods Club Treasurer
Re: oil pressure gauge info Sun, 13 February 2005 07:32 Go to previous messageGo to next message
Is there a way to work out what range the sender is?
I have a factory oil pressure gauge on my dash, and I want to wire it up. Problem is that with the engine change I'm planning, the sender is too big for the new block.
Also, the new block never came with an oil pressure sender, just the dead engine light, where should I fit a sender?
styler
Re: oil pressure gauge info Mon, 14 February 2005 00:26 Go to previous message
well you will need the matching sender for the guage, no point
in doing it any other way, then get adapters to fit your
block and use the oil idiot light location for the gauge sender
or use both the idiot light and sender together (recommended) by using a t splitter.
[Updated on: Mon, 14 February 2005 00:28]
Previous Topic:Summary: Live rear F/G diffs
Next Topic:trumpets / ram tubes weber 45mm
Current Time: Thu Nov 19 04:13:30 UTC 2026
Total time taken to generate the page: 0.45978093147278 seconds
