Toymods » Tech & Conversions » Big Brake Upgrade,Supra- A70/ Soarer- Z20
snail
Big Brake Upgrade,Supra- A70/ Soarer- Z20 Fri, 11 February 2005 13:39 Go to next message
Hi guy finally got the conversion under way. Here are the pics. As previous mentioned. It uses JZA80 325mm discs and Nissan 4spot calipers. Still trying to get a good firm price for group buy Smile
[Updated on: Fri, 11 February 2005 13:56]
Re: Supra- A70/ Soarer- Z20 Big Brake upgrade Fri, 11 February 2005 13:41 Go to previous messageGo to next message
errr.. is it just me, or can I see no pics?
snail
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Fri, 11 February 2005 14:07 Go to previous messageGo to next message
how do i put up pics in this section? Go to the Brake section in for sale. Smile
[Updated on: Fri, 11 February 2005 15:13]
fade-e
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Fri, 11 February 2005 15:45 Go to previous messageGo to next message
mate looking good, but it seems that the calipers are not big enough for the rotors. i dont know much about the JZA80 but couldnt you have used their calipers?
snail
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Sat, 12 February 2005 04:24 Go to previous messageGo to next message
First of all have you priced supra calipers recently?? Because those discs arent for those calipers it looks bad. All the pad facing are on the disc so its all good. Smile
HKS_TRD
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Sun, 13 February 2005 04:41 Go to previous messageGo to next message
Isnt this exactly what the Nightpager kit is, JZA-80 rotors and Nissan Calipers? How much is your kit going to be I know the Nightpager kit is not exactly cheap
snail
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 11:56 Go to previous messageGo to next message
All info for group buy is in the brake section. Tell you how it works soon. Have only dummy fitted atm. Trying to find wheels to fit. Need about 50ish offset looks like.
Allan
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 12:04 Go to previous messageGo to next message
be much better off maken an adaptor for the JZA80 4 pots IMHO
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 12:09 Go to previous messageGo to next message
I'm in agreeance with Allan. This is a very similar situation to what Michael was in with his MA61 brake upgrade. While it would probably work very well as is, it would be better to have a caliper with a larger pad area. Have a look at some of the EVO or STI Brembo stuff maybe as an alternative, or to open up the market so you might grab some cheaper.
As for the whole pad being used, the whole pad is used on the 280mm discs those calipers come with from the factory.
snail
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 12:11 Go to previous messageGo to next message
It would, but since the nissan calipers are a quater of the price its only logical.
Allan
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 12:15 Go to previous messageGo to next message
use the soarer 2pot sliding caliper perhaps
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 12:20 Go to previous messageGo to next message
Allan wrote on Mon, 14 February 2005 20:15
That I'd say would probably be a retrograde step, they are only for a 296mm rotor, so it would probably look very similar.
snail
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 12:22 Go to previous messageGo to next message
I would go two pots only because it wouldnt justify the costs involved. Nissan 4 spots do work very well. Yes it doesnt cover the disc but for the cost of alternative Brembo calipers the cost the exercise would not be justified for an everyday street car. End of the day it has to be affordable for us to enjoy. Thats how I read in to it.
Allan
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 12:30 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 14 February 2005 23:20
similer pad area tho from memory??
bbaacchhyy
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 20:49 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 14 February 2005 22:39
Yep, it is the case, but as pointed out, the Brembo's are very pricey.
Mind you, I picked up my Evo V pair for < $550, and you can buy NEW Porsche Monoblock calipers for about $750 each (and that is full retail), so someone with trade would get a better deal.....
snail
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 22:45 Go to previous messageGo to next message
Nissan 4spots cost under $300 a pair
bbaacchhyy
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Mon, 14 February 2005 22:53 Go to previous messageGo to next message
Yes, but then add in another $100 to cleanup/reseal, and the Porsche ones are bigger, monoblock, stiffer and have HUGE pads
The setup that you have come up with is a good compromise for a reasonable price
Michael B
HKS_TRD
Re: Big Brake Upgrade,Supra- A70/ Soarer- Z20 Tue, 15 February 2005 09:27 Go to previous message
What we need is the Alcon Grex kit or Brembo F40s, if someone else pays for it
Previous Topic:front pannels off a late model corolla to fit a ke70
Next Topic:7m ge cylinder head
Current Time: Fri Nov 20 13:34:31 UTC 2026
Total time taken to generate the page: 0.010303020477295 seconds
