Toymods » Tech & Conversions » 4age Help
86DRFT
Rockhampton QLD
icon5.gif  4age Help Sat, 12 February 2005 11:43 Go to next message
hi, my rwd bigport 4age's timing is set at 50 degrees and when turned down it doesnt work. i've found this has happend to a few people and the only idea's are that the throttle position sensor is stuffed or the car is stuck in diagnostic mode. any more ideas? also where can i get a new TPS for this thing, toyota? please help asap.
thanks, Pat
86DRFT
Rockhampton QLD
Re: 4age Help Sat, 12 February 2005 18:39 Go to previous messageGo to next message
a part number would be good too Smile
IRA11Y
Club Member
Re: 4age Help Sun, 13 February 2005 00:34 Go to previous messageGo to next message
uhmm you are putting the car into diagnostic mode when checking the timing arent you??? and the idle is set within factory limits?
I think i recall factory idle bieng 7-800rpm or maybe its 8-900rpm??
you need to bridge T1 and TE1 connectors before you start the car to check the timing
86DRFT
Rockhampton QLD
Re: 4age Help Sun, 13 February 2005 05:15 Go to previous messageGo to next message
thanks for the reply. the idle is fine, i'll ask the mechanic which checked it if he bridged the connectors.
cheers, Pat
86DRFT
Rockhampton QLD
Re: 4age Help Sun, 13 February 2005 07:32 Go to previous message
looks like the current TPS is off a fwd bigport and has been modified to fit... badly. i really need a rwd TPS, has anyone got a spare tvis intake setup? it hangs of the side of that.
cheers, Pat
Previous Topic:rc crank same as rg??
Next Topic:MA61 heater controls help
Current Time: Sun Oct 18 01:13:31 UTC 2026
Total time taken to generate the page: 0.006770133972168 seconds
