Toymods » Tech & Conversions » which sparkplugs for 1st gen 4age?
froodogs
Perth, WA
which sparkplugs for 1st gen 4age? Tue, 29 October 2002 11:28 Go to next message
running an ae86 with a tvis map sensored gen 1 4age. Only just got it recently. Anyway, the sparkies are covered in black shite, so.... i need some new ones.
so yeah, what sort should i get?
1bam777
Perth WA
Re: which sparkplugs for 1st gen 4age? Tue, 29 October 2002 11:49 Go to previous messageGo to next message
NGK BCPR5E-N-11 are perfectly fine for a standard motor, and if you're looking at platinium plugs, then go for NGK BCPR5EP-11. Don't have to use NGKs, but they are most commonly available. I use NGKs and Champions. If you want to go a heat range colder, the subsitute the '5' for a '6'. Don't really recommend it though.
Cheers.
froodogs
Perth, WA
Re: which sparkplugs for 1st gen 4age? Tue, 29 October 2002 12:59 Go to previous message
heh.
zacka you big stalker you... Wink
heh, um, well, you've seen my motor, you've poked around in it... assuming the biggest upgrade likely to occur in the life-span of these spark plugs is a new exhaust system...
any real difference between platinum/non platinum?
Previous Topic:Ke36 info, 4k info?
Next Topic:wheels do they fit????????
Current Time: Tue Oct 20 22:34:51 UTC 2026
Total time taken to generate the page: 0.051048994064331 seconds
