Toymods » Tech & Conversions » Oil Leak - 4A-GE
Initial_D
February 2005
Oil Leak - 4A-GE Sun, 13 February 2005 09:32 Go to next message
I have a 4AGE and I noticed that there is oil leaking under neath. I haven't looked close yet but does anyone know whereabouts I should start looking?
EVOSTi
cambo
      no
Re: Oil Leak - 4A-GE Sun, 13 February 2005 09:37 Go to previous messageGo to next message
are you gonna be able to fix it if you find it? take it to a mechanic.
Re: Oil Leak - 4A-GE Sun, 13 February 2005 09:38 Go to previous messageGo to next message
i suggest looking at either the engine, the gearbox, or the diff.... or possibly the brakes..
Nolan
Campbelltown, NSW
Re: Oil Leak - 4A-GE Sun, 13 February 2005 09:41 Go to previous messageGo to next message
did u put the sump plug back in...Razz
CHEERS
NOLAN
Initial_D
February 2005
Re: Oil Leak - 4A-GE Sun, 13 February 2005 09:48 Go to previous messageGo to next message
Nolan wrote on Sun, 13 February 2005 19:41
CHEERS
NOLAN
I never changed the oil.
Re: Oil Leak - 4A-GE Sun, 13 February 2005 09:56 Go to previous messageGo to next message
seriously dude, just actually start looking...
oil is wet and oily. you could even just use your clean finger to touch stuff to see where the oil is...
the trick is, oil usually goes DOWN, so there will be oil BELOW the leak.
if you look with your eyeballs, you will see where the oil is coming from.. simple as that..
when you see where it comes from, then diagnose why it's leaking..
if that's too much.. mechanic time...
Initial_D
February 2005
Re: Oil Leak - 4A-GE Sun, 13 February 2005 10:06 Go to previous messageGo to next message
oldcorollas wrote on Sun, 13 February 2005 19:56
I only just got it and drove in back from Brisbane (8 hour drive) and arrived back not to long ago and realised that there is oil leaking but I am to tied to check it at the moment and thought I would come on here and see if there has been any problems with the 4AGE engine's at all.
Re: Oil Leak - 4A-GE Sun, 13 February 2005 10:15 Go to previous messageGo to next message
all engines (even new ones) can leak oil, and usually do from somewhere. just have a look tomorrow and it should be apparent where it's coming from... that will help you narrow down the question of why it's leaking Smile
IRA11Y
Club Member
Re: Oil Leak - 4A-GE Sun, 13 February 2005 10:26 Go to previous messageGo to next message
its probhably the radiator, 4age's have a big problem leaking oil out of the radiator.
ae86drift
sydney.au
Re: Oil Leak - 4A-GE Sun, 13 February 2005 11:12 Go to previous messageGo to next message
IRA11Y wrote on Sun, 13 February 2005 21:26
lol
dont be mean
b1gb3n
south Melbourne/KL
Re: Oil Leak - 4A-GE Sun, 13 February 2005 16:55 Go to previous messageGo to next message
maybe its from the fuel lines??
Re: Oil Leak - 4A-GE Sun, 13 February 2005 18:16 Go to previous messageGo to next message
b1gb3n wrote on Mon, 14 February 2005 03:55
yes, thats it bigboy.. nice detective work....... Rolling Eyes
shinybluesteel
melbourne
Re: Oil Leak - 4A-GE Mon, 14 February 2005 07:17 Go to previous messageGo to next message
mine leaked oil when i filled it up, but i put the dizzy in and then it (the oil) went into the engine instead of out the dizzy hole and onto the grass.
hope this helps Very Happy
4agte
Toronto, Downtown
Re: Oil Leak - 4A-GE Mon, 14 February 2005 08:12 Go to previous messageGo to next message
The front or rear main seal could have had it usually the front main seal is gone. This is located near the oil pump and usually means that oil will leak all over the sump. If this is your problem and your gonna get it fixed you might as well change the timing belt and the water pump while your at it.
feral4mr2
Bundaberg, Qld.
Re: Oil Leak - 4A-GE Mon, 14 February 2005 10:33 Go to previous messageGo to next message
one of the common places for a oil leak on the 4age/ze is from the distributor oil seal. one way to check is lean into your engine bay and run your finger under the dizzy, it comes out all oily then that's probably where it's leaking from.
maybe you should give it a degrease and go for a quick spin and see if you can spot where the oil is coming from like oldcorollas mentioned. put it up on some car ramps if you have any, will make it heaps easier to see where it might be coming from.
EVOSTi
cambo
      no
Re: Oil Leak - 4A-GE Mon, 14 February 2005 10:49 Go to previous messageGo to next message
dood we were trying to have a serious discussion Laughing
Re: Oil Leak - 4A-GE Mon, 14 February 2005 12:27 Go to previous message
Give it a good clean down as said, and see if you can get friendly with some kind of local mechanic and if they'll let you put the car on a hoist for a few minutes in exhange for a few $/cans. It's lovely to be able to walk under a car and see what's up with it!
Previous Topic:JZZ30 1JZ- VL Conversion Wiring Help
Next Topic:2tgeu injection
Current Time: Fri Oct 30 22:50:56 UTC 2026
Total time taken to generate the page: 0.00711989402771 seconds
