Toymods » Tech & Conversions » Do we need O2 sensor???
Johnny_K
Perth WA
Do we need O2 sensor??? Sun, 13 February 2005 13:44 Go to next message
Hey just wondering. I got a stockish 4AGE bigport (JDM) with 4-1 aftermarket extractors (kelhams?). I bought it like this and notice it has no O2 sensor on the extractors like the stock manifold would have. Just wondering do i need a O2 sensor to make the car run alot better, i have a random problem my mechanic friend says that the car is injecting more fuel than usual and gradually thr car wil flood and cant start up for like a day. But yeah do i need a O2 sensor??? THANKS JoHnNy_K
Re: Do we need O2 sensor??? Sun, 13 February 2005 13:56 Go to previous messageGo to next message
If there's meant to be a sensor there, you should use one.
The flooding problem won't be anything to do with that though, sounds like a leaking injector.
Johnny_K
Perth WA
Re: Do we need O2 sensor??? Sun, 13 February 2005 14:03 Go to previous messageGo to next message
Why leaking injectors????. Well anyways the mechanic dude reckons its ECU realated which he'll check this week, so which i think having no O2 sensor could be the problem, the ECU doesnt know ma air/fuel ratio thus it injects more fuel , but thanksfor the help anyway i need ideas to find the prob
berad
Re: Do we need O2 sensor??? Mon, 14 February 2005 05:28 Go to previous messageGo to next message
if its stock ecu u need one well it will run btter
Toobs
Re: Do we need O2 sensor??? Mon, 14 February 2005 07:19 Go to previous messageGo to next message
Get the oxy sensor installed in your exhaust after the extractors.
It will help with your mixtures... but your problem with starting is something more than just an oxy sensor.
Have you got the right map sensor on the car?
Fr3aK
Wollongong
January 2005
Re: Do we need O2 sensor??? Mon, 14 February 2005 23:58 Go to previous messageGo to next message
I drove my car with NO O2 sensor and NO exhaust manifold once. It was farking loud, but other than that ran fine. Rolling Eyes
It is a 1996 V6 Vienta, and has 2 O2 sensors fitted standard.
I'm not saying "take your O2 sensor off, you'll be fine" i'm just saying the car can drive without it.
Re: Do we need O2 sensor??? Tue, 15 February 2005 00:03 Go to previous messageGo to next message
The only problem is it'll never be able to go into closed loop and as such, your fuel economy will probably be crap.
Joshstix
Toymods Vice President
Re: Do we need O2 sensor??? Tue, 15 February 2005 00:06 Go to previous messageGo to next message
And you should get check engine lights all the time.
Fr3aK
Wollongong
January 2005
Re: Do we need O2 sensor??? Tue, 15 February 2005 00:20 Go to previous messageGo to next message
Joshstix wrote on Tue, 15 February 2005 11:06
Shocked i didn't! WTF?
Hunty
Re: Do we need O2 sensor??? Tue, 15 February 2005 03:22 Go to previous messageGo to next message
O2 sensor is a two trip fault.
it has to fail or not be connected twice while running to make the ecu light come on, AFAIK
and yes fuel economy will be shit house try less than 300kms out of 40litres in a ae82 100kw 4age without the o2 sensor compared with over 500ks with it
other than that tho it will run, just mega rich.
Johnny_K
Perth WA
Re: Do we need O2 sensor??? Tue, 15 February 2005 04:11 Go to previous messageGo to next message
Well the mechanic dude said my injectors are injecting more fuel than usual which sometimes causes my car to flood and not start for like a day or so (very annoying!!!) .SO i guess if its running mega rich (when cold you can see fuel being spat out of ma exaust), installing a 02 sensor could solve my problem????
[Updated on: Tue, 15 February 2005 04:12]
Hunty
Re: Do we need O2 sensor??? Tue, 15 February 2005 04:18 Go to previous messageGo to next message
i dont think the O2 sensor will help the not starting thing.
you might possibly have a leaking injector which is dripping fuel into the cylinder even when the engine is turned off, hence flooding the engine and it not being able to start.
either way get a new o2 sensor they are not expensive, well most arent. then see how that goes if you've still got problems i'd have your injectors cleaned/flow tested. then check the spark plugs/leads/coil/dizzy/battery/alternator
parrot
Re: Do we need O2 sensor??? Tue, 15 February 2005 06:13 Go to previous messageGo to next message
I ran my 4ag for a long time without an O2 sensor. When I finally decided to connect it up for no particular reason, made absolutely no difference to anything. I do run a VAF sensor (UK engine loom), but as far as I know, only makes a difference at idle.
Re: Do we need O2 sensor??? Tue, 15 February 2005 06:20 Go to previous messageGo to next message
parrot wrote on Tue, 15 February 2005 14:13
If it's working correctly, it'll be working at light loads and cruising when the ECU should switch into closed loop. You'll notice the difference in a big way if you do lots of highway driving.
No Message Body
[Updated on: Tue, 15 February 2005 06:20]
Re: Do we need O2 sensor??? Tue, 15 February 2005 07:31 Go to previous messageGo to next message
justcallmefrank wrote on Tue, 15 February 2005 17:20
zactly... funny how the same thing needs to be said a few times before it sinks in Wink
for my megasquirt, i have O2 closed loop working:
above 77 degrees C (coolant)
above 2000rpm
below 65kpa (absolute manifold pressure)
if any of those conditions are not met, it goes out of closed loop.. it basically means only highway driving, and steady/trailing throttle. it can make a big difference tho, but if your tuning is close, then it might be only 5% difference.
BradW
Bottom of the hill, Sydney
Re: Do we need O2 sensor??? Tue, 15 February 2005 10:23 Go to previous messageGo to next message
Johnny_K wrote on Tue, 15 February 2005 15:11
Are you sure it's fuel and not just condensation/water. If it is fuel then I think you will also need a new catalytic converter.
Brad
parrot
Re: Do we need O2 sensor??? Wed, 16 February 2005 01:00 Go to previous message
The U.K. cars don't actually run an O2 sensor. As I said, they do have a VAF sender which I was of the impression only affected idle quality. Not sure how U.K. cars handle cruising conditions. I have used both a U.K. supplied standard ECU plus a japanese standard ECU with no discernible change.
Previous Topic:Cruise control on RA-23
Next Topic:2T-G to 2T-GEU
Current Time: Sat Oct 17 13:33:18 UTC 2026
Total time taken to generate the page: 0.0071489810943604 seconds
