Toymods » Tech & Conversions » welding stuff to a cast exhuast manifold ??
ed_ma61
Lost in the K hole
icon4.gif  welding stuff to a cast exhuast manifold ?? Tue, 29 October 2002 13:14 Go to next message
how easy is it to weld bits onto a cast exhaust manifold??
ie: welding bits of pipe onto it with a good seal/join ??
in the past ive heared that welding to cast material is a no-go zone, but thought it were worth asking specifically about exhaust mani's...
i mean, people build entire extractors using an old exhaust manifold flange dont they, so it must be possible to do... or dont the welds last or something???
ed
[Updated on: Tue, 29 October 2002 13:16]
JIMMYD
Cairns
Re: welding stuff to a cast exhuast manifold ?? Wed, 30 October 2002 05:44 Go to previous messageGo to next message
I have welded cast with stick welder and WIA cast iron rods. PITA. Can be done, but you REALLY have to want it.
JIMMYD
Re: welding stuff to a cast exhuast manifold ?? Wed, 30 October 2002 06:11 Go to previous messageGo to next message
Apparently the cast needs to be heated to a cherry red color, then welded, and then allowed to cool. Apparently there are probs with the welds just cracking. It can be done but is a major PITA.
Read here for a summary of the problems. These guys are selling a special cast rod and presenting it as if it were a magical cure-all.
Brazing might be another way around the problem.
feral4mr2
Bundaberg, Qld.
Re: welding stuff to a cast exhuast manifold ?? Wed, 30 October 2002 12:20 Go to previous messageGo to next message
when i modified my cast manifold, i got the turbo flange 'brazed' on, that shit is tough, works heap better and easier than welding, also did it with the dump pipe....
all the searching i did on the web, recommened 'brazing' cast...
TE72_Turbo
Re: welding stuff to a cast exhuast manifold ?? Wed, 30 October 2002 12:28 Go to previous messageGo to next message
A mechanic mate of mine has modified several cast dump pipes and turbo exhaust flanges off nissan RB series motors, they seem to have high quality metal in their castings, and have had no problems after a few years of use.
He heats them up with an oxy first, then welds with high current on a MIG, to get good penetration.
dunno about the quality of toyota cast parts.
5KinKP60
Finland
Re: welding stuff to a cast exhuast manifold ?? Wed, 30 October 2002 21:46 Go to previous message
This one professional welder told me that heat treatment _after_ welding does the trick.
He for example welded up this one truck exh header. He used stick weld, some kinda 'chrome'-stick.
Anyways, wlded the crack up, installed header, and used engine itself to do the heat treatment.
Switched engine on for 1 to 2 minutes, had it idling all time. Swicth off, cooling period. After a while, switch back to idle, leave it running longer, cool down again.
Work this way carefully towards normal temperatures.
Apparently if it has inbuilt stresses inside wlding, it'll crack during first time it's running. If it'll make trhrough one day, it won't (most likely) crack at weld seam.
He said that sometimes on construction sites they ne really long drill bits. Those are done on site. Just weld on a rod onto a drill bit. He said it's cruicial to use blow torch to after welding to heat it until dark red - then have it cool down slowly.
If after treatment not done - drill bit will eventually crack away from metal rod.
-A.
Previous Topic:Brass Button Clutch (what is)
Next Topic:4agze Flywheel bolts.. torque?
Current Time: Fri Nov 20 06:14:25 UTC 2026
Total time taken to generate the page: 0.0052230358123779 seconds
