Toymods » Tech & Conversions » 20v idle PROBLEMS
Leighp
NY
icon9.gif  20v idle PROBLEMS Tue, 29 October 2002 16:43 Go to next message
Attention Bill sherwood, Jason or anyone that knows for that matter:
I have an idle problem on my 20v, it idles at about 1100 - 1300 rpm, how do i tune it back down to the recommended 850 rpm??
Also what oils do you fellas recommend for the engine and box?? Do you also recommend genuine toyota oil filter or is an after market one ok??
Finally: and the tough one: how do you change the AFM to a MAP sensor, or is it possible to add the black top MAP parts to change it or will it be a nightmare??
Thanks for all the help
EvilJack
Sutho/Hills NSW
Re: 20v idle PROBLEMS Fri, 20 December 2002 07:26 Go to previous messageGo to next message
*bump*
im geting same problem
how did you fix it?
Leighp
NY
Re: 20v idle PROBLEMS Sun, 22 December 2002 15:07 Go to previous messageGo to next message
Oxy sensor what the little bandit that caused the probs
Good luck mate
LP
EvilJack
Sutho/Hills NSW
Re: 20v idle PROBLEMS Mon, 23 December 2002 11:11 Go to previous messageGo to next message
nah it was actually connected.
there was an extra valve on the power steer pump which applied more acceleration when on full turn. So just blocked it off and idles fine around 700rpm.
Leighp
NY
Re: 20v idle PROBLEMS Mon, 23 December 2002 15:16 Go to previous message
makes sense go for 800-850, small tuning though
Previous Topic:1jz ma61 overheating
Next Topic:Gearbox info
Current Time: Fri Oct 16 14:48:03 UTC 2026
Total time taken to generate the page: 0.029118061065674 seconds
