Toymods » Tech & Conversions » Coilover Sleeve KITS
dispatcher
Malaysia,Kuala Lumpur
Coilover Sleeve KITS Mon, 14 February 2005 15:38 Go to next message
Anyone here tried these SLEEVE KITS type coilovers ? Are they any good,maybe as good as a full threded body type ?
Any good or bad reviews ?
Please your thoughts and input.
M.W.P.
Rocky Mountains, Canada
Re: Coilover Sleeve KITS Mon, 14 February 2005 15:58 Go to previous messageGo to next message
If they are made and installed properly, there should be no difference at all between the kits and the full coilover struts.
Ill probably be ordering a sleeve kit from importbitz for my RT132 struts shortly Smile
dispatcher
Re: Coilover Sleeve KITS Mon, 14 February 2005 16:05 Go to previous messageGo to next message
OH goody..not to mention cheaper ?
Please..more input...NEED INPUT Very Happy
bbaacchhyy
Re: Coilover Sleeve KITS Mon, 14 February 2005 20:46 Go to previous messageGo to next message
M.W.P. wrote on Tue, 15 February 2005 02:28
Didn't notice the kits on their site ?
What is the price ?
Maybe can order two and save on postage since you are in Adelaide ?
Michael B
barned01
Re: Coilover Sleeve KITS Mon, 14 February 2005 22:17 Go to previous messageGo to next message
price of sleeve kits i think was 275 + postage of 10 bucks (to adelaide) i asked only last week.
Hey BBaacchhyy are you sensing group buy?
bbaacchhyy
Re: Coilover Sleeve KITS Mon, 14 February 2005 22:41 Go to previous messageGo to next message
Possibly, but what is included ?
I don't need springs as I already have them. From memory, Fulcrum wanted $80 for the pair of sleeves, another $80 for the top hats, and something for the spanner. May ring and recheck.
Michael B
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Mon, 14 February 2005 22:43 Go to previous messageGo to next message
Be aware that there are 2 types of kit - ones with steel sleeves, that you have welded on, and ones with aluminium sleeves, which you have to get a steel ring made up and welded on, and then the sleeve sits on top of.
bbaacchhyy
Re: Coilover Sleeve KITS Mon, 14 February 2005 22:50 Go to previous messageGo to next message
OK, from Fulcrum, the alloy sleeves (with 2 nuts) are $55 ea, the top caps are $55 ea, and the spanner is $17.
With freight of $15 to Adelaide, the total cost is about $252 without springs.
Michael B
takai
Re: Coilover Sleeve KITS Mon, 14 February 2005 23:03 Go to previous messageGo to next message
Or you could do what i did and get the T3 upper hats which are FAR superior to the crappy Fulcrum ones. They are around $80 delivered, depending on the current exchange rate.
Also the fulcrum ones need to be machined out slightly on the inside to fit sprinter/*T13* struts.
barned01
awaiting response from importbitz to find out what is with the kit
Re: Coilover Sleeve KITS Mon, 14 February 2005 23:11 Go to previous messageGo to next message
Check with Noltec as well. Toymods gets a 25%discount.
bbaacchhyy
Re: Coilover Sleeve KITS Mon, 14 February 2005 23:16 Go to previous messageGo to next message
takai wrote on Tue, 15 February 2005 09:33
Yes, I saw the pics after a search and noticed that they come with a flat bearing, so will probably go with those - at AUS $80, they are cheaper than the Fulcrum ones as well.
Will try Noltec
Michael B
EDIT :
Spoke to Noltec, and their list price for their Kits is $470, and member price is $400, but note the sleeves are steel, not alloy.
http://www.noltec.com.au/coil-over-suspension-syst ems.php
For Adelaide people, their local distributor is Cartorque (Ph. 8362 7667) and their price price (for the 51mm ID kit) is $330 incl GST.
Didn't pressure for a better price at this stage
[Updated on: Mon, 14 February 2005 23:29]
barned01
Re: Coilover Sleeve KITS Tue, 15 February 2005 02:44 Go to previous messageGo to next message
ok importbitz kit includes:
"there are two steel sleeves, threaded, two alloy top hats, two threaded lower seats and two threaded lock rings"
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Tue, 15 February 2005 02:53 Go to previous messageGo to next message
For those who are getting aluminium sleeve kits... anyone care to get a mini-group buy happening on the steel rings that have to be made up and welded to the strut for the sleeves to sit on?
This is one part that never comes in kits, and the outside (2"? )diametre of all xA6xs, xA4xs, xA2xs and AE86 struts is the same (proabaly all rwd celica/supra/corolla/corona etc are) so it would be applicable to a lot of toymodders.
M.W.P.
Re: Coilover Sleeve KITS Tue, 15 February 2005 03:01 Go to previous messageGo to next message
bbaacchhyy wrote on Tue, 15 February 2005 09:46
Cartorque is selling the Noltec kit for less than Noltec does?
barned01
Re: Coilover Sleeve KITS Tue, 15 February 2005 03:18 Go to previous messageGo to next message
ok why would the alloy ones be preferred over the steel sleeve kit and please don't say it is a weight issue.
Re: Coilover Sleeve KITS Tue, 15 February 2005 03:54 Go to previous messageGo to next message
Yeah exactly, why would use alloy? its just more work.
I have steel ones and was all too easy to slide them on and weld.
bbaacchhyy
Re: Coilover Sleeve KITS Tue, 15 February 2005 04:03 Go to previous messageGo to next message
TurboRA28 wrote on Tue, 15 February 2005 14:24
Alloy can be anodised all sorts of colours, therefore look more swanky.
I can easily organise a set of steel rings for those with the alloy ones, I'd just need to ID of the struts that people require them for, as well as an indication of what people would pay ?
From the correspondence above, it seems that the best alloy setup is the sleeves + spanners from Fulcrum, top hats from T3, and custom steel rings, and for the steel setup would be from Cartorque (for the Adelaide people).
Probably they (cartorque) can sell it for less due to their commercial agreement with Fulcrum, and it depends on their markup.
Another option to replace the steel ring for the alloy sleeves was to use the "U" part of an exhaust U Band clamp (slightly dodgy and not the prettiest, but it works).
If I were to start organising something like this, who would be interesetd in what option ? Please state alloy or steel and where you are located, and of course qty.
If sufficient replies were rec'd, I'd approach the board for permission, and then take it from there
Michael B
bbaacchhyy
Re: Coilover Sleeve KITS Tue, 15 February 2005 04:13 Go to previous messageGo to next message
barned01 wrote on Tue, 15 February 2005 13:14
Can you get pics at all so we can compare apples with apples ?
Do you get an adjsuting spanner ?
Are the threaded saets/rings steel or alloy ?
M.W.P.
Re: Coilover Sleeve KITS Tue, 15 February 2005 04:38 Go to previous messageGo to next message
bbaacchhyy wrote on Tue, 15 February 2005 14:43
Importbitz
I can supply steel sleeves, with the alloy lock rings and alloy top hats to suit for $299inc GST
Ive asked about the C spanners and for some photos.
[Updated on: Tue, 15 February 2005 04:38]
dispatcher
Re: Coilover Sleeve KITS Tue, 15 February 2005 05:34 Go to previous messageGo to next message
Yesss pics plenty of pics...for Old Schooler toyotas like my GX60..i know pretty much how the front will be made up.I've seen it on the net..but the rear shocks..You know like KE 70/GX60/AE86..i still can't picture how it'll work ?
cheers all
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Tue, 15 February 2005 05:42 Go to previous messageGo to next message
bbaacchhyy wrote on Tue, 15 February 2005 15:03
Michael B
I don't care whether it's alloy or steel... whatever kit ends up being the best kit at the best price, factoring in the extra $$ needed for the rings for the alloy kits. Most people probably feel the same. I seem to remember being told that alum sleeves, if anodised, have tougher threads. Another thing to consider is the ring - if a long sleeve, would probably need to be a d-shape to clear wheels etc (unless of course the ring isn't very thick).
I was going to buy my set from the states, an alum sleeve kit like the ground control ones which is decent civic kit that only needs the top had drilling out a little wider. Same strut ID as our cars - 2".
barned01
Re: Coilover Sleeve KITS Tue, 15 February 2005 06:40 Go to previous messageGo to next message
Well i think M.W.P will beat me to it to find that out Sad (pictures, the spanner and the rings)
Yeah i haven't worked out how to do adjustable everything for the back yet either Dispatcher...one step at a time.
M.W.P.
Re: Coilover Sleeve KITS Tue, 15 February 2005 06:54 Go to previous messageGo to next message
Stefan wrote on Tue, 15 February 2005 16:12
I cant see how anodising alloy can make it stronger than steel...
Myself, i would prefer steel sleeves as it should be easier to get engineered and past rego (which i have to do).
As i said earlier, the importbitz kits have alloy rings.
I also just found out they dont have C spanners and cant get them.
They should get pics for me soon...
[Updated on: Tue, 15 February 2005 06:56]
dispatcher
Re: Coilover Sleeve KITS Tue, 15 February 2005 08:31 Go to previous messageGo to next message
Point taken barned01...will do the front and then the back... Very Happy
Anyone else heard of this Sleeves..failing..I.e. fatigue..cracks etc...
takai
Re: Coilover Sleeve KITS Tue, 15 February 2005 08:50 Go to previous messageGo to next message
The sleeves dont tend to crack and ive seen some alloy ones after a fairly long time. Depends though.
Im currently using the Fulcrum sleves, which had to be machined out on the inside to fit the XT130 struts. Here are some pics:
This is the Fulcrum sleeve, with the T3 top hat and an Eibach spring: http://www.dysfunction.ws/galleryapp/Sprinter/DSCF 0002_004
The T3 upper hats foul on the Cusco camber tops:http://www.dysfunction.ws/galleryapp/Sprinter /DSCF0014_004
Solution: http://www.dysfunction.ws/galleryapp/Sprinter/DSCF 0006_012
Installed: http://www.dysfunction.ws/galleryapp/Sprinter/DSCF 0016_004
Feel free to ask away on questions.
Purple_Beasty
New Zealand
Re: Coilover Sleeve KITS Tue, 15 February 2005 09:01 Go to previous messageGo to next message
For the rear setup, you can get slip on sleeves as used in some speedway cars. Worth investigating, will need to reinforce shock mounts though.
Callum
Re: Coilover Sleeve KITS Tue, 15 February 2005 09:17 Go to previous messageGo to next message
takai wrote on Tue, 15 February 2005 18:50
Do you have anymore pictures of the camber tops? I have some Kmacs but i'm trying to figure out if I should get others Confused
takai
Re: Coilover Sleeve KITS Tue, 15 February 2005 10:43 Go to previous messageGo to next message
There are a few more in http://gallery.dysfunction.ws/ Ill edit this post when i find more.
dispatcher
Re: Coilover Sleeve KITS Tue, 15 February 2005 11:02 Go to previous messageGo to next message
Hey Purple Beasty..thanks for the info..i'm ignorant about speedways car setups...I just can't picture it in my head Sad Sad any pics available ? ..on the net maybe ?
bbaacchhyy
Re: Coilover Sleeve KITS Tue, 15 February 2005 20:44 Go to previous messageGo to next message
takai wrote on Tue, 15 February 2005 19:20
Thanks for the pics and details takai.
How long ago did you get the spring tops ?
Michael B
takai
Re: Coilover Sleeve KITS Tue, 15 February 2005 21:54 Go to previous messageGo to next message
I got the tops about 10 months ago from T3, but didnt get to use them until September.
Re: Coilover Sleeve KITS Tue, 15 February 2005 22:52 Go to previous messageGo to next message
Ok i'll bite. Who/where is T3?
Re: Coilover Sleeve KITS Tue, 15 February 2005 23:05 Go to previous messageGo to next message
http://www.technotoytuning.com/
Purple_Beasty
New Zealand
Re: Coilover Sleeve KITS Tue, 15 February 2005 23:20 Go to previous messageGo to next message
http://www.cardwells.co.nz/products.php?CategoryID =42&BrandID=12&PHPSESSID=d2c858507d72ba5ef a4c5b4cb3ad8be6
Hard to see but they have a lip at the top that sits them on top of the shock body.
http://www.cardwells.co.nz/images/final/137.jpg
Will try to get some clearer pics of the ones on my brothers speedway car this weekend.
Callum
bbaacchhyy
Re: Coilover Sleeve KITS Wed, 16 February 2005 00:02 Go to previous messageGo to next message
Purple Beasty,
These look very much like the ones that 935Motorsports in the US sell. The only thing that counts against that kit is the single lower spring perch, and that it has a grub screw to lock it to the threaded portion which can damage the threads.
I very much like the T3 Spring tops as they have the flat bearing, but as seen in takai's pics, they may need a spacer.
[Updated on: Wed, 16 February 2005 00:03]
Purple_Beasty
New Zealand
Re: Coilover Sleeve KITS Wed, 16 February 2005 00:13 Go to previous messageGo to next message
If I was using them (which I may do) I would ditch the grub screw and get a second nut.
Callum
bbaacchhyy
Re: Coilover Sleeve KITS Wed, 16 February 2005 00:23 Go to previous messageGo to next message
Purple_Beasty wrote on Wed, 16 February 2005 10:43
Callum
I'd be interested in the price of them if that option is available.
Keep me posted please
Michael B
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Wed, 16 February 2005 03:40 Go to previous messageGo to next message
FWIW I believe they are QA1 items.
bbaacchhyy
Re: Coilover Sleeve KITS Wed, 16 February 2005 03:49 Go to previous messageGo to next message
Stefan wrote on Wed, 16 February 2005 14:10
They are, and I'm waiting on confirmation of price including an extra sleeve.
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Thu, 17 February 2005 01:52 Go to previous messageGo to next message
FWIW, I just emailed importbitz - the sleeve kit is $299. It includes:
2 x steel threaded sleeves in diameter of choice
2 x alloy top hats
2 x adjustable spring perchs
2 x adjustable lock rings
2 x C spanners can be bought as an option for additional $44pr
Apparently is Koni.
M.W.P.
Re: Coilover Sleeve KITS Thu, 17 February 2005 07:03 Go to previous messageGo to next message
More info from importbitz:
Quote:
Sleeve inside diameters come in the sizes below:
55mm, 2.125", 2", 50mm, 48mm
These can be supplied with spring seats to suit 60, 63 or 65mm springs and have a tube length of 120mm.
They are also available the following ID sizes which have a tube ength of 75mm and suit 53mm and 57mm springs.
The 45mm also comes with a tube length or 90mm to suit 60mm springs.
45mm, 42.2mm, 43mm, 41mm
i2obert
Re: Coilover Sleeve KITS Thu, 17 February 2005 20:26 Go to previous messageGo to next message
so how do these work ???? do you weld the sleve to your standed or aftermarket shock ?? and there you go type thing ??
and they should fit any car ??? mx83 cressida im looking for becouse it seems all we can get as of coilovers is jzx81 shocks so this whould be good for me and other cressie drivers
and do you think there whould be ways to get short stroke ones bah good one guys i want these now Very Happy
[Updated on: Thu, 17 February 2005 20:28]
bbaacchhyy
Re: Coilover Sleeve KITS Thu, 17 February 2005 20:35 Go to previous messageGo to next message
i2obert wrote on Fri, 18 February 2005 06:56
WTF ? The only question I could decipher was the first one.
Look at the links provided by Takai and it should make sense.
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Fri, 18 February 2005 00:27 Go to previous messageGo to next message
i2obert wrote on Fri, 18 February 2005 07:26
Don't take this the wrong way... but if you don't know the difference between a "shock" and a strut, I don't think you should be attempting a DIY coilover conversion. Do some reading.
The more I've been thinking about this, the more I'm thinking steel sleevs are a much better way to go - so I'm definetly up for a group buy.
Re: Coilover Sleeve KITS Fri, 18 February 2005 08:51 Go to previous messageGo to next message
I'm in for a group buy.
M.W.P.
Re: Coilover Sleeve KITS Fri, 18 February 2005 10:09 Go to previous messageGo to next message
Whats the most common coilover spring size (ID)?
i2obert
Re: Coilover Sleeve KITS Fri, 18 February 2005 10:40 Go to previous messageGo to next message
sorry about that post as you see it was very early in the morning ?? i do know the difrence between them just was tierd and in a rush sorry once again can these be made with difrent springrates and so on as i whouldt mind somthing that whould replicate the kai office coilovers for a jzx81
and spoke to a guy at work who has these on his clubman car he said just have to watch out what struts you use with these as some of them screw up at the bottom when the bar hits them over and over agian peaces the bottom after a while
bathurst-91
Re: Coilover Sleeve KITS Fri, 18 February 2005 12:17 Go to previous messageGo to next message
Actually Takai I think T3 have changed the shape of their hats Wink
Hence they no longer fowel on the cusco tops!
http://members.optushome.com.au/creed01/coilovers 001b.jpg
ok, so bad pic.. but they work out fine.
[Updated on: Fri, 18 February 2005 12:18]
Re: Coilover Sleeve KITS Fri, 18 February 2005 12:43 Go to previous messageGo to next message
Do the cusco tops have any kind of shock absorbing in them?
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Fri, 18 February 2005 14:38 Go to previous messageGo to next message
Bathurst-91 - what brand is the sleeve kit in the pics? Or was it bought pre-assembled?
MAZMAN
Re: Coilover Sleeve KITS Sat, 19 February 2005 06:48 Go to previous messageGo to next message
any pictures of the fulcrum kits?
they seem to be the cheapest out there!
I would also be in the group buy Smile
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Sun, 20 February 2005 12:51 Go to previous messageGo to next message
Bump - perhaps we could organise a group buy with Importbitz? I believe most rwd toys would use exactly the same sleeve - 2". They are a toymods sponsor.
bbaacchhyy
Re: Coilover Sleeve KITS Sun, 20 February 2005 20:52 Go to previous messageGo to next message
Stefan wrote on Sun, 20 February 2005 23:21
3 people have responded/shown interst, and personally, I'd be after an alloy kit.
Since you are more interested in the steel option Stefan, why not pass an email after a price for 5 + kits
[Updated on: Sun, 20 February 2005 20:53]
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Mon, 21 February 2005 02:01 Go to previous messageGo to next message
bbaacchhyy wrote on Mon, 21 February 2005 07:52
Will do.
Apart from price, why would you prefer alloy over steel? You have to get rings made up, and then have the issue of metal rubbing on metal (most alloy kits come with lots of rubber o-rings to combat this), wheras a steel kit is weld on and no worries.
bbaacchhyy
Re: Coilover Sleeve KITS Mon, 21 February 2005 02:10 Go to previous messageGo to next message
Stefan wrote on Mon, 21 February 2005 12:31
Will do.
Slight bling factor, cost and I can access machining services easy.
Metal rubbing is not an issue if you get the right size. The o-rings are only supplied in generic kits so they make only one size.
At the very least, the sleeve should almost be a shrink fit onto the strut tube.
That said, I'd be interested to see what the final price from John is (including a spanner)
Michael B
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Mon, 21 February 2005 04:16 Go to previous messageGo to next message
Here' you go:
1-4 $290
5-9 $275
10+ $260
postage australia wide via express bag is $9.50
I'll ask again about the spanners.
bbaacchhyy
Re: Coilover Sleeve KITS Mon, 21 February 2005 04:42 Go to previous messageGo to next message
As a summary : (based on single units)
Fulcrum : $237 + postage (alloy sleeves, 2 locknuts per sleeve, 2 spanners, 2 top hats)
Fulcrum + T3 : $210 + postage (alloy sleeves, 2 locknuts per sleeve, 2 spanners, 2 T3 top hats (waiting on confirmation from T3 on price of hats))
Import Bitz : $334 + postage (steel sleeves, 2 locknuts per sleeve, 2 (?) spanners, 2 top hats)
Cardwells (like QA1) : NZ $180 + postage (alloy sleeves, 1 locknut per sleeve, spanners ?, 2 top hats) - waiting on confirmation of price of extra locknut and if spanners are included or extra
Noltec : $330 + postage (steel sleeves, 2 locknuts per sleeve, 2 (?) spanners, 2 top hats)
Kings : $257 + postage (alloy sleeves, 2 locknuts per sleeve, 2 spanners, 2 top hats) (prices are RRP, awaiting actual price from local distributor - Quoted $362 from local supplier - so did Kings stuff up their price over the phone ???)
Thoughts anyone ?
EDIT : Added King Springs pricing, again 22/2/02 11:30am
[Updated on: Tue, 22 February 2005 00:53]
Stefan
Hobart, Tas
Re: Coilover Sleeve KITS Mon, 21 February 2005 04:57 Go to previous messageGo to next message
Try King Springs??? They sell all the components, but the web site is unfriendly.
bbaacchhyy
Re: Coilover Sleeve KITS Mon, 21 February 2005 05:27 Go to previous messageGo to previous message
Stefan wrote on Mon, 21 February 2005 15:27
Kings prices added above...
Previous Topic:How does a Crank angle sensor Work?
Next Topic:Sprinter will not go into reverse....
Current Time: Fri Nov 20 04:36:19 UTC 2026
Total time taken to generate the page: 0.013614892959595 seconds
