Toymods » Tech & Conversions » RA40 to RA60 front strut conversion info required
rexxxy
RA40 to RA60 front strut conversion info required Mon, 14 February 2005 22:38 Go to next message
Hi all,
Im in the market for a pair of new / 2nd hand struts to sauit my RA40 Celica. However someone suggested that the RA60 would be a better buy. Can anyone tell me what is required in order to swap from RA40 to RA60 front struts? Is it a straight bolt in which I can do myself or is there surgery required?
And if anyone has a pair of front struts laying around which they would like to convert to cash, let me know!
barned01
Re: RA40 to RA60 front strut conversion info required Mon, 14 February 2005 22:51 Go to previous messageGo to next message
what do you need the ra60 struts for that the ra40 can't.
Except for maybe easy upgrades using nissan callipers.
something i would like to try myself though to correct the positive camber issue they apparently give would be to perform a rack and pinion conversion that turbora28 has performed then you kill 2 birds with one stone. the R&P conversion according to Blackra28 increases track width...so...
you get rack and pinion AND you get an ra60 strut with no positive camber issues.
rexxxy
Re: RA40 to RA60 front strut conversion info required Tue, 15 February 2005 03:34 Go to previous messageGo to next message
Well the car cost me $100. Its got leaking front struts right now which is holding me back from getting an RWC. Otherwise the car is sound, so I was originally looking for a pair of front struts, someone said the RA60 struts would be a better buy as they have bigger brakes etc.. So my question was whats required to install the RA60 struts. Not interested in a major conversion as I use the car to get to and from the train station.
If anything difficult is involved.. Then I will just get a good 2nd hand pair of RA40 struts.
Allan
Re: RA40 to RA60 front strut conversion info required Tue, 15 February 2005 03:39 Go to previous messageGo to next message
are your ra40 struts the original oil filled items or poxy monroe inserts... if there the original oil ones clean and refill with cheapo engine oil or if you wana lash out goto a motor bike place and get propper damper oil
Allan
Re: RA40 to RA60 front strut conversion info required Tue, 15 February 2005 08:27 Go to previous messageGo to next message
Getting it to work properly is difficult, because the camber angles are all wrong. If you want something easy, forget the RA60 struts.
rexxxy
Re: RA40 to RA60 front strut conversion info required Wed, 16 February 2005 02:54 Go to previous message
Thanks mate, thats the info I was after..
The seals are gone in the original struts, so I cant rebuild them, they would just leak again.. So im goignt ohave to track down some good 2nd hand ones.. I think a guy on here has a pair so i will chase them up.. Thanks for your help
Previous Topic:Oil Sensor Location on 4age??
Next Topic:size of front speakers in ae82 seca?
Current Time: Fri Jun 26 11:20:29 UTC 2026
Total time taken to generate the page: 0.0056838989257812 seconds
