Toymods » Tech & Conversions » Cruise control on RA-23
Petes76celica
Cruise control on RA-23 Mon, 14 February 2005 23:10 Go to next message
hey guys i was wondering if anyone has done this conversion but put cruise control on an 18RG engine or any thing else that has Carbys.
Pete
Bugman
Re: Cruise control on RA-23 Mon, 14 February 2005 23:12 Go to previous messageGo to next message
I once put a back on the accelerator pedal on a long trip.. worked a dream
ra23celica
Re: Cruise control on RA-23 Tue, 15 February 2005 00:38 Go to previous messageGo to next message
If you are really serious about this then the 'best' way to tackle it would be to adapt a hand throttle cable and knob from a diesel engined 4WD and attach that to your carby linkages, in a way that does not interfere with the normal operation of the throttle pedal.
Really, if you just can't keep your foot on the pedal in one position for a long time, use a brick.
Re: Cruise control on RA-23 Tue, 15 February 2005 03:11 Go to previous messageGo to next message
Or just buy an aftermarket kit and bolt it on.
There should be ones out there designed for carbies.
gold28
Madrid - Spain
Re: Cruise control on RA-23 Wed, 16 February 2005 00:04 Go to previous messageGo to next message
The hardest part will the speed sensor. I guess you could put a magnetic one on the prop shaft. The rest should be fairly simple to do.
Re: Cruise control on RA-23 Wed, 16 February 2005 01:28 Go to previous message
Magnet on the prop shaft is how all aftermarket ones work.
The hardest thing will be hooking up a cable to the carby, as most kits are suited to the throttle body setup.
Previous Topic:Camber from brake/strut conversion
Next Topic:Do we need O2 sensor???
Current Time: Sat Oct 17 03:00:55 UTC 2026
Total time taken to generate the page: 0.0061378479003906 seconds
