Toymods » Tech & Conversions » 6 speed aw11 questions.
subsonicaudio
Kingaroy
icon3.gif  6 speed aw11 questions. Tue, 15 February 2005 06:59 Go to next message
Is it at all possible to use the sixspeed box from a blacktop 20 valve in a aw11 mr2.
Wouldn't i simply have to change the linkages?
I'm not sure on the strength of this box, would it support a 4agte producing 200rrkw?
davedave
Re: 6 speed aw11 questions. Tue, 15 February 2005 07:08 Go to previous messageGo to next message
Try these on for size
I'd say the C60 would be very similar to the C160
http://www.mk1point5.com/6speed.htm
And I'd suggest joining up with www.mr2oc.com if you haven't already
http://www.mr2oc.com/showthread.php?t=39949&hi ghlight=fwd+gearbox
As for strength, I don't really know.
Logic tells me though, C series gearbox = poo
mr2gze
Re: 6 speed aw11 questions. Tue, 15 February 2005 11:15 Go to previous messageGo to next message
Ive got no experience with this so im guessing
but i rekon the linkages on the c160 would be on the opposite side to the aw11 gearbox(s), with the casing on the gearbox where the linkage comes out of also being different, aw11 facing north, c160 facing south. I doubt it would be as simple as bolting off limkage section from aw11 box and onto c160 simply because the case itself is different. Im sure its possible tho, with some clever linkages etc
as for stength i doubt its as strong as the e5x box
corolla madness
Re: 6 speed aw11 questions. Tue, 15 February 2005 12:25 Go to previous messageGo to next message
From what i have heard the 6 speed C series box from a 20v will get eaten by a 4agte.
Mr Revhead
nelson, new zealand
Re: 6 speed aw11 questions. Wed, 16 February 2005 00:18 Go to previous messageGo to next message
yes, munch munch
and why do you want a 6speed?the ratios are such that it doesnt make much difference, and with the extra torque your engine has theres no need for 6 gears...
subsonicaudio
Kingaroy
Re: 6 speed aw11 questions. Wed, 16 February 2005 06:59 Go to previous messageGo to next message
thanks for the info guys it's been helpful. As to why i want a 6 speed.............Not too much reason I was wondering whether being the 6 speed i'd be able to put around @ 100km with out having to do 3200rpm, that's prob the big reason other than of course the show appeal.
Hunty
Re: 6 speed aw11 questions. Wed, 16 February 2005 07:14 Go to previous messageGo to next message
[quote}
1989 aw11, 2 bar of boost, hks turbo, custom intercooler, custom plenum, 100mm hsv throttle body, 100 hp shot zex nitrous, wiseco forged rods, adjustable cam gears, stage 2 cams, trd valves, trd shim kit, trd short shift kit, bigport head, 4agze bottom end, exedy twin plate clutch, lightened flywheel, greddy e-manage, 4agze pistons, 550cc supra injectors, custom fuel rail, malpassi rising rate fuel regulator, bosch 500hp fuel pump, custom surge tank and 20L fuel cell........SOOOOOOOO MUCH FUN
[/quote]
omg thats gotta be a monster, 28psi of boost??? damn!!
subsonicaudio
Kingaroy
Re: 6 speed aw11 questions. Wed, 16 February 2005 07:31 Go to previous messageGo to next message
Yeah but it's not running, the standard 4agze pistons (AE101) were not up to the job and have fried and the injectors are running out off puff at 7800rpm it;s been built to redline at 9000rpm, I'm saving for some wiseco forged pistons and 1000cc injectors. I don't even know what power it's makin it blew on the first run at 2 bar, and that was after running everthing in for 3500km. It's proving to be very expensive and time consuming to make a 200+ rrkw mr2!
fatmr2
Re: 6 speed aw11 questions. Wed, 16 February 2005 07:48 Go to previous messageGo to next message
subsonicaudio wrote on Wed, 16 February 2005 18:31
I feel your pain Crying or Very Sad
I just put 1000k's on mine when it blew. Bad toyota parts Mad
On that last note......Yes very $$$$
Hhmmmmmm........yet another who wants 200+rwkw? Good luck man, i hope you get it. I know what its like to want that Smile
Have you used the nos yet?
Re: 6 speed aw11 questions. Wed, 16 February 2005 08:02 Go to previous messageGo to next message
subsonicaudio wrote on Wed, 16 February 2005 17:59
bah humbug, stop yer whinin Wink
4500rpm at 100km is not that annoying.... 4800 would be tho.
why not change diff ratios? means you can stay in gear longer (since you have the torque, and gearchanging is what will slow you down) AND lower high speed rpm.
is the 6th a second overdrive? or is it a normal 5th with 5 close ratios going up to 1:1?
adamaw11
February 2005
Re: 6 speed aw11 questions. Thu, 17 February 2005 01:16 Go to previous messageGo to next message
The guy here is putting the 6 speed in.
http://www.20vmki.com/index1.html?section=20vswap& amp;content=20vswap/transmission.html
looks like he's doing it by swapping over the selector shafts.
subsonicaudio
Kingaroy
Re: 6 speed aw11 questions. Thu, 17 February 2005 05:36 Go to previous message
No I havn't used the nos yet the engine blew while dialling in the boost on its first major dyno run, just while i'm here does anyone know where to get a set of nitto drag radials to suit a 205 40 17 wheel?
Previous Topic:ke20 hub conversion
Next Topic:4A GZE aftermarket fuel regulator
Current Time: Tue Oct 20 13:05:19 UTC 2026
Total time taken to generate the page: 0.0053410530090332 seconds
