Toymods » Tech & Conversions » Which diff would be better for my sprinter?
Currently-Carless
Which diff would be better for my sprinter? Tue, 15 February 2005 08:11 Go to next message
Was down at the local wreckers today, and they had two complete rear ends available, and I was wondering which one is easier to fit into and aus spec sprinter.
The first is an RT132 diff with code T312 out of a corona, and the second is a TE72 diff with code T302 out of a T18. Of the two, the corona diff looked cleaner as the T18 diff had a lot of surface rust on it and also some oil stain marks on the bottom of the actual diff. Both have panhard rod mounts. I am leaning more towards the T18 diff as I know it is a direct bolt up. But will have to get it rebuilt by a diff specialist. Anyone know if the Corona diff is a direct bolt up as well? Would like to know asap as I want to get either one before they both disappear. Also what is an easy way to test if the diff is ok?
Henn
Rosanna, Melb
Re: Which diff would be better for my sprinter? Tue, 15 February 2005 11:40 Go to previous message
Corona will be more work to make it fit.
Don't bother having a T-series diff rebuilt. Just clean it out and add new oil, you may as well weld it while it's apart too...
Hen
Previous Topic:sprinter hub patterns
Next Topic:help, car is being silly
Current Time: Wed Oct 21 15:52:20 UTC 2026
Total time taken to generate the page: 0.0053179264068604 seconds
