Toymods » Tech & Conversions » Camber from brake/strut conversion
ta2272
Camber from brake/strut conversion Tue, 15 February 2005 09:05 Go to next message
My car has very good suspension setup koni shocks, heavy duty springs and big sway bars, the front seems like it not gripping or tacking a corner as happily as it should be.
It is a ta22 with ra40 conversion unsure if they cut and shut or how they do the conversion but just wondering if anybody knows what this conversion does to camber or handling in general.
Jason
M.W.P.
Rocky Mountains, Canada
Re: Camber from brake/strut conversion Tue, 15 February 2005 09:45 Go to previous messageGo to next message
You running a rear swaybar?
ta2272
Re: Camber from brake/strut conversion Tue, 15 February 2005 10:34 Go to previous messageGo to next message
yes
M.W.P.
Re: Camber from brake/strut conversion Tue, 15 February 2005 12:19 Go to previous messageGo to next message
ta2272 wrote on Tue, 15 February 2005 21:04
yes
Big or standard?
NAMDAMAMI
England
Re: Camber from brake/strut conversion Tue, 15 February 2005 16:38 Go to previous messageGo to next message
Are you using those spacers that fit between the bottom of the strut and the steering knuckle? (I think there known as anti-dive kits).
Re: Camber from brake/strut conversion Tue, 15 February 2005 21:06 Go to previous messageGo to next message
Roll Centre adjusters (RCAs)
I'd get the camber measured. I go down to bob jane and they print out a really detailed report of camber, castor, toe, all for the front and rear. It's really helpful when trying to setup the car.
Joel
NAMDAMAMI
England
Re: Camber from brake/strut conversion Tue, 15 February 2005 22:13 Go to previous messageGo to next message
Roll centre adjusters, that's the one.
Anyway, if you have them and your car is not lowered sufficiantly for these to be required, it will give you positive camber.
The front of the car will feel like it's on the tips of its toes and not grip.
Bloody awfull if you ask me.
Re: Camber from brake/strut conversion Tue, 15 February 2005 23:14 Go to previous messageGo to next message
Yeah a degree or 2 of negative camber can do wonders for front end grip Smile
I just recently got mine all setup correctly and have around 1.5 degree of negative camber and understeer is a thing of the past.
Also having some extra caster helps as this creates dynamic camber.
Joel
gold28
Madrid - Spain
Re: Camber from brake/strut conversion Tue, 15 February 2005 23:24 Go to previous messageGo to next message
If the front anti-roll bar is too big relative to the rear one then it will have an understeering tendancy.
As joel said, get some wheel alignment info and then we will be in a better position to help.
ra23celica
Re: Camber from brake/strut conversion Tue, 15 February 2005 23:50 Go to previous messageGo to next message
In the short term if I were you I would be tempted to get a tape measure onto the struts and determine the length of them now and compare that to the length of stock TA22 struts.
ta2272
Re: Camber from brake/strut conversion Wed, 16 February 2005 01:49 Go to previous message
front saway bar is something like a 27mm so it is quite huge, and the ta22 didnt come with a rear but it has something like a 14mm on the back which make it almost to tali happy, i shall get the camber measured, im getting tyres at bridgestone i wonder if they can measure it.
Jason
Previous Topic:size of front speakers in ae82 seca?
Next Topic:Cruise control on RA-23
Current Time: Tue Oct 13 18:06:10 UTC 2026
Total time taken to generate the page: 0.039753913879395 seconds
