Toymods » Tech & Conversions » 1JZ rear main seal, JZA70 steering rack boots and engine mounts.
Mofo III
Kelmscott, Perth, W.A
1JZ rear main seal, JZA70 steering rack boots and engine mounts. Tue, 15 February 2005 18:05 Go to next message
if one doesnt want to pay rediculous prices for these parts from geniune toyota where else is one to source these parts?
im not sure wreckers are the answer for these particular parts.
Cheers.
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Tue, 15 February 2005 20:27 Go to previous messageGo to next message
With regard to the rubber boots, you should be able to buy these from any auto parts store. They will very likely be identical to an MA70 one, but bring a sample to be sure.
As for main seals, a bearing shop will have these. Of course they won't have a listing so you'll need to bring in a sample or at least have some dimensions for them to work from (inner/outer diameter, depth).
Search the forums for engine mounts....it has been covered. They are quite expensive from Toyota ($300 each rings a bell), but there were some posts recently about cheaper alternatives.
mz21_shiznac
Bunbury, W.A.
January 2005
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Tue, 15 February 2005 23:05 Go to previous messageGo to next message
Well I work at repco in Bunbury, as like most stores we have books on almost anything, so rip all of the stuff out and then go and match it up, quite easy.
snail
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Wed, 16 February 2005 04:53 Go to previous messageGo to next message
It pays to buy genuine stuff when it comes to seals. Rack boots you can get the $10 universal ones and just fit them. Smile
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Wed, 16 February 2005 04:57 Go to previous messageGo to next message
snail wrote on Wed, 16 February 2005 12:53
HAHahAHAHAHAHA oh thats funny.
When was the last time a seal (or bearing for that matter) was made by Toyota?
Toyota use Koyo, and then charge 300% more than a bearing place.
snail
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Wed, 16 February 2005 08:38 Go to previous messageGo to next message
So that is to say rear main for a 1JZ "äfter market" costs $20. Confused
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Wed, 16 February 2005 08:51 Go to previous messageGo to next message
Rear main seals for almost every engine cost $15-$20.
EDIT: And thats RRP at parts store.
Cost will be under $10.
Although, the 1GGTE one cost $40 trade for some reason.
Still haven't worked that one out.
[Updated on: Wed, 16 February 2005 08:52]
snail
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Wed, 16 February 2005 09:19 Go to previous messageGo to next message
Confused This is for a 1J
Mofo III
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Tue, 05 April 2005 03:05 Go to previous messageGo to next message
damnit i forgot about this thread and have since bought rear main, cam and crank seals, timing belt and some othe shiznit all genuine (trade price) that totalled over $160.
at least i know its gonna fit eh Razz
i might take the seals down to transeals and get them to replicate them all and mass produce them, then flog them off here cheap! Smile
or maybe not.
Rattlehead
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Tue, 12 April 2005 02:20 Go to previous messageGo to next message
Yeh do it coz Toyota are annoying to get stuff from.
Expensive, slow, not interested blah blah blah...grrr
manmx83
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Tue, 12 April 2005 15:06 Go to previous messageGo to next message
Hey Darv.
Re Toyota being difficult to deal with,possible exception is castle hill toyota in sydney.there is a good guy in there who is happy to deal with import stuff.
Mounts.someone suggested checking "mackays automotive rubber manual" near front of manual is selection of rubber cushion mounts.
Cheers.Pete. Smile
EvilJack
Sutho/Hills NSW
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Tue, 12 April 2005 21:57 Go to previous messageGo to next message
is this the guy with the queer voice? if so he has major mood swings Razz
wilbo666
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Sat, 30 April 2005 03:16 Go to previous messageGo to next message
I took my existing 1jz rear main into the local bearing shop, and $10.80 later I had a new one.
I'll list the part numbers of both the old and new at some stage.
Mofo III
Re: 1JZ rear main seal, JZA70 steering rack boots and engine mounts. Sat, 30 April 2005 06:39 Go to previous message
small update:
i ended up buying genuine seals including, 2 cam seals, crank and rear main seals, did cost abit, i think the rear main was $60 or something crazy like that, but i didnt have the time to look for substitutes, interestingly enough i think they gave my a 2jz rear main, seemed to fit ok.
i still plan on taking my old seals in to get replicated for the future.
as for rack boots i just went to repco and bought generic rack boots for like 10 bux each, they fit nice and tight.
and engine mounts i found a bloke in the u.s with a 2nd hand set from a low km jza70 front cut, i was very skeptical but compared to genuine newies they were dirt cheap, $50 for both including metal brackets and bolts, ive fitted them myself prior to installing a gearbox, and even after tilting the motor to fit the box they still held up, if they were weak or ready to pop they would have then.
when these do let go ill take my dead ones to woodsies windscreens in perth who are confident they can remake them. which should work out cheaper than genuines.
Previous Topic:3SGE -> 3SGTE (ST162)
Next Topic:ECU Compatibility across models ? Tech advice needed.
Current Time: Sat Nov 21 01:43:18 UTC 2026
Total time taken to generate the page: 0.014603137969971 seconds
