Toymods » Tech & Conversions » 3K Starter Motor
Bradelz
Tamworth
3K Starter Motor Tue, 15 February 2005 21:35 Go to next message
Hey,
Before you go off at me for not using the search function - i tried it and found nothing - i also tried using google where i found a interesting site but you have to pay money to ask a question.
So i was wondering my starter motor in my 3K every so ofter when you try turning the car over it will just turn the starter motor and not the engine, it takes 3 goes before it cranks the engine, so i'am going to take it out and take it too a auto elect.
Anyways, i've heard you have to take the exhaust manifold off? Is there any other way to do it? Like squeezing it from underneath?
Thanks guys,
Brad
rob_RA40
c'town, NSW
Re: 3K Starter Motor Tue, 15 February 2005 22:12 Go to previous messageGo to next message
does it make a loud screech/grind noise when it happens?
are u positive the starter is turning when it doesnt engage?
Purple_Beasty
New Zealand
Re: 3K Starter Motor Tue, 15 February 2005 23:24 Go to previous messageGo to next message
Depending on the car and exhaust it can be a very tight fit to get out. From memeory you unbolt it and slide it forward to wards the engine mount, then drop the snout of it down and pull it out. Can be fiddly to do.
Callum
Bradelz
Tamworth
Re: 3K Starter Motor Tue, 15 February 2005 23:48 Go to previous messageGo to next message
Hey thanks for the comments,
Rob: It just doesnt engage with the engine like it goes rrrrrhhhh and then 2 more trys and it engages and the engine goes, no loud noises or anything no screeches.
Purple_beasty: Yeah i'll try that cus stuff pulling the manifold off and shit like that,
Brad
styler
Re: 3K Starter Motor Wed, 16 February 2005 00:58 Go to previous messageGo to next message
it could be bad contacts to the solenoid, if not...
it seems the starter is ok, its the solenoid that
doesnt engage and pull the gear onto the flywheel,
from what you have described. i think you can get
replacement solenoids.
as for getting it off...
<runs off to look at car>, hmmm looks like a dog
to get out, it *might* be able to get it out once
the two bolts are undone from underneath if you are
lucky, remembering to disconnect battery before lol.
Redwarf
February 2005
Re: 3K Starter Motor Wed, 16 February 2005 04:13 Go to previous messageGo to next message
If you have a standard exhaust, it'll come out with a bit of fiddling. With most aftermarket extractors it'll come out, too. Sadly, my extractors have to come out to change mine.
gr8r-x
Vic, AU
Re: 3K Starter Motor Wed, 16 February 2005 07:21 Go to previous messageGo to next message
Got the same problem in mine!
I find it's only hard to start if left for a while... Same symptons though.
And, it is possible to remove it, as the rest have said. Done it before and I'll have to do it again. Very Happy
BradW
Bottom of the hill, Sydney
Re: 3K Starter Motor Wed, 16 February 2005 08:47 Go to previous messageGo to next message
styler wrote on Wed, 16 February 2005 11:58
If it was bad contacts or the solenoid not throwing out the starter would not be motoring. In fact it would just make one click and that would be it.
It is more than likely going to be the clutch in the starter has failed or the fork arm has broken. Either way the starter has to be removed and disassembled to be repaired.
Brad
Bradelz
Tamworth
Re: 3K Starter Motor Wed, 16 February 2005 10:53 Go to previous messageGo to next message
Hey,
Thanks for the help guys,
gr8r-x: with mine it will start you dont have to wait, like when you turn it and it doesnt engage you do it again after it has stopped spinning and it will always kick.
BradW: thats what i was thinking, take the whole thing out and take it too a auto elect.
Thanks again,
Brad
allencr
tallahassee FL usOFa
Re: 3K Starter Motor Wed, 16 February 2005 15:47 Go to previous message
it's the bendix/starter drive/starter drive clutch/starter one way drive - different names, all the same thing.
it will get worse, probably gradually, but maybe stop completly.
it's only the drive, but it's usually easier & cheaper for most people to replace the entire thing.
Previous Topic:whats a t series diff from?
Next Topic:Toy diesel + k50... tough tech
Current Time: Sat Oct 17 23:25:02 UTC 2026
Total time taken to generate the page: 0.019658088684082 seconds
