Toymods » Tech & Conversions » safc wiring 1g
Ribbo
Northern Beaches
safc wiring 1g Tue, 15 February 2005 22:34 Go to next message
I have an sacf 2 and installing it on my 1g-gte.
When I run the motor the revs read at half what they should be. I have set it to 6 cylender. There are 2 rpm wires on the wiring diagram but im only using rpm1. Do I need to wire rpm2 into it somehow?
Re: safc wiring 1g Tue, 15 February 2005 23:34 Go to previous messageGo to next message
What connections does it say you have to make, and where are you getting them from?
Fr3aK
Wollongong
January 2005
Re: safc wiring 1g Wed, 16 February 2005 00:42 Go to previous messageGo to next message
Here's a quote from my SAFC manual:
"A'PEXi Japan wrote in Fr3aK's SAFC manual"
In the case of the plural connection, connect to engine RPM signal 2
Bascially forget about the RPM 1 wire, and just hook it upto the RPM 2 wire.
See if that works.
[Updated on: Wed, 16 February 2005 00:44]
Ribbo
Northern Beaches
Re: safc wiring 1g Wed, 16 February 2005 05:12 Go to previous messageGo to next message
ahh what a bugger, safc2 manual doesnt say anything about that, thanks ill give it a go
improvedae86
Re: safc wiring 1g Wed, 16 February 2005 06:16 Go to previous messageGo to next message
The rpm signal two wire is only connected on some models . From memory its only rb26dett , plural i think they mean spilt coil pulses to ecu . Theres something in the manual about that .
I have seen this problem before , you might need to press the next button a few time to safe your changes . Sometimes it doesn't save the setting first time Crying or Very Sad
Ribbo
Northern Beaches
Re: safc wiring 1g Wed, 16 February 2005 11:06 Go to previous messageGo to next message
i think the duel stuff it talks about for rb26 is for the air flow meter being duel, might be wrong though.
Do you mean make sure it is save to 6 cyl? it definatly is
it won't idle very well which i guess is to do with the rpm being wrong.
Fr3aK
Wollongong
January 2005
Re: safc wiring 1g Thu, 17 February 2005 05:59 Go to previous messageGo to next message
The duel thingy is for the twin AFM's on GTR's.
Have you tried putting the rpm wire into ECU RPM 2 location yet?
If in doubt; talk to a professional!
Ribbo
Northern Beaches
Re: safc wiring 1g Thu, 17 February 2005 07:05 Go to previous messageGo to next message
no i havn't tried yet, currently only have 1 hand after some surgery on tuesday. hopefully it will solve it
Ribbo
Northern Beaches
Re: safc wiring 1g Fri, 18 February 2005 03:12 Go to previous message
got dad to fix the rpm wires and yep that was the problem, all good now. thanks guys
Previous Topic:6 Speed in Ma70
Next Topic:Broken Speedo, info?
Current Time: Thu Oct 22 07:54:12 UTC 2026
Total time taken to generate the page: 0.0058000087738037 seconds
