Toymods » Tech & Conversions » exhausts and mufflers for a 1JZ
exhausts and mufflers for a 1JZ Wed, 30 October 2002 06:39 Go to next message
I know this has been covered before, but I'm looking a few specifics.
I'm getting a 3" system on the 1JZ, and I'm tossing up between a sports muffler or just a stocky, quiet one.
I don't mind my car being loud, as long as it's legal.
I'm thinking if I put a sports exhaust on it, with my hi flow cat, I'll need to add a resonator, but how much will a stock muffler impede the 1JZ? (bearing in mind it will receive some mods, up to 350bhp at least)
also, to go stainless or mild steel? how much heavier would a 3" stainless system be than mild steel? if it's only a kg or 2, I'll go stainless... but if it's too much then I may as well go a mild system
[Updated on: Wed, 30 October 2002 06:41]
Bounty
_Sydney _
Re: exhausts and mufflers for a 1JZ Wed, 30 October 2002 08:52 Go to previous messageGo to next message
ive been looking around for an exhaust system for my 1jz and im still undecided for now, but i know stainless costs a shit load.
Pete
gold coast
Re: exhausts and mufflers for a 1JZ Wed, 30 October 2002 11:33 Go to previous messageGo to next message
Keep in mind a GOOD muffler is about $160 at least.
I made my own 3.5' system and muffler, it was LOUD when i gave my car some stick.
During the upcoming hoildays i will be making another exhaust but in 3 inch and this time i will be buying a muffler.
The reason for the dia change is that 24 YO cars were not meant to have 3.5 inch systems, they made it allergic to speed humps and air time.
Keep ground clearance in mind when thinking about an exhaust.
Soarer
Wollongong
Re: exhausts and mufflers for a 1JZ Thu, 31 October 2002 03:03 Go to previous messageGo to next message
Yeah, ground clearance can be an issue... unfortunately not one that I thought about when getting my 3" system. The cat covertor now scrapes on most speed humps if I go any faster than ~3km/h.
This might have something to do with the car being ~4" lower than normal at the same time though Razz
Re: exhausts and mufflers for a 1JZ Thu, 31 October 2002 05:29 Go to previous messageGo to next message
well, I only plan on lowering the mk2 1 or 2 inches ... so hopefully clearance shouldn't be too much of an issue.
ed_ma61
Lost in the K hole
Re: exhausts and mufflers for a 1JZ Thu, 31 October 2002 05:33 Go to previous messageGo to next message
walker/dynomax make some excellent triple pass, large volume, 3" in/out mufflers. they have excellent flow rates, and are QUIET Smile .
theyre reasonably cheap, and available through repco.
if you download their .pdf catalogue, you can have a look at all the configurations they manufacture.
ed
SUPRAGTE
North Sydney
Re: exhausts and mufflers for a 1JZ Thu, 31 October 2002 11:53 Go to previous messageGo to next message
You'd have to go straight through, a triple pass would be quite restrictive. A straight through isn't loud at all, my car is straight through and it's very quiet.
With twins and mongy "y" piece noise wouldn't be an issue, go for flow.
Re: exhausts and mufflers for a 1JZ Thu, 31 October 2002 13:04 Go to previous messageGo to next message
mongy y-piece?
celicamad
newcastle
Re: exhausts and mufflers for a 1JZ Thu, 07 November 2002 11:50 Go to previous messageGo to next message
The main thing is 3 inch Mandrel bent straight through mufflers
and if you want to reduce resonation instead of a reso run a straight through(as in you can SEE though it ) small oval muffler in place of the reso and a largish (same design) rear
...VERY QUIET ...GOOD flow
[Updated on: Thu, 07 November 2002 12:09]
Re: exhausts and mufflers for a 1JZ Thu, 07 November 2002 11:54 Go to previous messageGo to next message
so you're saying, run a cat, then one of those race-type mufflers (that have a barrel 1" wider than the exhaust), then a typical sports hi-flow muffler on the end?
sounds like a good idea.. just what I'm after
celicamad
newcastle
Re: exhausts and mufflers for a 1JZ Thu, 07 November 2002 12:12 Go to previous messageGo to next message
exactly !!! at 1 bar should make about 240 HP @ wheels
hey hows my typing????
Later get rid of the y section and get some twin pipes
then will make about 270 H.p at wheels but with heaps more torque
Soarer
Wollongong
Re: exhausts and mufflers for a 1JZ Thu, 07 November 2002 12:57 Go to previous messageGo to next message
Celicamad !
Just wanting your opinion on my exhaust setup, and if you can offer any advice.
3" mandrel bent from the Y pipe (not twin pipes yet!) to a hi-flow 3" cat, then splitting into dual 3" mandrel pipes to two straight through mufflers at the rear.
The car is very quiet at idle, but drones a bit while driving. Any suggestions/comments?
Also, do you reckon I've got it setup for optimal power ? (In your opinion) Haven't had it dyno'd yet, but totally stock I pulled 185HP at the rear.
1G-GTEFreAk
icon4.gif  Re: exhausts and mufflers for a 1JZ Sat, 16 November 2002 13:27 Go to previous messageGo to next message
Laughing what exhaust system would ou recommend on the 1G-GTe engine on a toyota chaser 1990.Iwas thinking apexi N1 ,It looks good but is it a noisy exhaust or does it have a deep sporty sound suitable for street and city touring. Cool
celicamad
newcastle
Re: exhausts and mufflers for a 1JZ Thu, 30 January 2003 11:24 Go to previous messageGo to next message
sorry i somehow missed this post
i know its old but ive been asked to reply
My advice is simple run a straight through 3 or 3 and 1/2 inch sytem with a resonator and a rear muffler (loud)
or swap reso for oval straight through muffler.twin cats is heaps better in fact my twin cats flow as good as punched 3 inch but im legal .
The ultimate system is twin 2.5 into single 3.5 with twin cats 1 oval muffler and 1 rear straight through quiet and great flow
the twins should join just past the gearbox
YB1-CAM
Re: exhausts and mufflers for a 1JZ Sun, 02 February 2003 08:54 Go to previous messageGo to next message
celicamad,
any tips for a good setup for a 1986 Corolla Twincam Hatch?
thunderbird1
Sydney Australia
Re: exhausts and mufflers for a 1JZ Mon, 03 February 2003 03:01 Go to previous messageGo to next message
go see bruce at charlestown exhaust blacktown... does a great job and is a nice fella. 3inch system with big arse rear muffler sounds great for me. Is quiet off boost and as some people have heard sounds great on boost Wink Get a removable cat, and then you can have it even quieter when you want to run around fully legal.
viagra_cressida
Balranald
Re: exhausts and mufflers for a 1JZ Mon, 03 February 2003 04:42 Go to previous messageGo to next message
After 'putting up with' a LOUD exhaust on my Commodore I am scared to put a big one on the Soarer because i'm enjoying the quietness. I would like a little more noise but not too much more but would be hoping for more power. Is there any chance of getting a system that only increases the noise a little but will have a good increase in power? Would a well made dump pipe of the turbo going into something like 2.5 -3 inch going into standard mufflers make sense or am I making you guys cringe??
Re: exhausts and mufflers for a 1JZ Mon, 03 February 2003 04:45 Go to previous messageGo to next message
the y-piece on the 1jz is a HUGE impedence to flow... replace that with somethihng decent and you'll get quite noticeable power gains
1jzmx83
Re: exhausts and mufflers for a 1JZ Mon, 03 February 2003 05:43 Go to previous messageGo to next message
Have any of you guys got a rough price for having twin dump pipes made up?
Soarer
Wollongong
Re: exhausts and mufflers for a 1JZ Mon, 03 February 2003 05:57 Go to previous messageGo to next message
From what I've heard, ~$450 for the pipes.
Ollygt
Re: exhausts and mufflers for a 1JZ Wed, 05 February 2003 10:43 Go to previous messageGo to next message
I've been thinking about that Y piece, you know there's a limitation on power output for cars in Japan when they leave the factory, a limiting exhaust would be one of the easiest ways to lower power, that and a detuned rom.
As much as Like the V8 sound I'm glad my brother is leaving his V8 soarer with the factory muffler setup so its niiicccce and quiet, so mr policeman doesn't look at it.
viagra_cressida
Balranald
Re: exhausts and mufflers for a 1JZ Thu, 06 February 2003 07:09 Go to previous message
Here here Ollygt!! I love having a such quiet car!
If only you could have both a quiet car and a fast car....not that a TT Soarer is slow but I would like to go a little faster
Previous Topic:2tgeu info
Next Topic:Scotts Hydraulic suspension conversion - QLD
Current Time: Thu Oct 29 19:57:52 UTC 2026
Total time taken to generate the page: 0.026345014572144 seconds
