Toymods » Tech & Conversions » Bottom Feed Injectors (Hi Flow Methanol) Advice needed
nath
Parramatta NSW Australia
February 2005
Bottom Feed Injectors (Hi Flow Methanol) Advice needed Wed, 16 February 2005 02:36 Go to next message
Hi Everyone,
My first post here, I live over at the V8 forum at www.lextreme.com
I am currently building a Drag car powered by a Toyota 1UZ-FE V8
which will be blown from a roots 6:71 supercharger running EFI and methanol fuel.
I am designing a custom throttle body/injector plate and my design sqecificly requires the use of Bottom / side Feed injectors with a 90 degree connector only.
I cannot use any top feed or 45 degree bottom feed injectors as they simply will not suit my design.
I am not an expert on injectors and would like some help in suitable Bottom feed 90 degree connector injectors.
Here are some details I can give on the requirments.
I will be using a Microtec computer and am looking at injectors flowing over 550cc.
I would use 8 x 550cc injectors (or larger).
Or 16 x 330cc injectors (or equivilant small flow figures).
They would be sequentially fired in groups depending on what is allowed via the computer.
Fuel pressure has not been decided until number and flow on injectors has been set.
Comp ratio is 8.5:1 running forged pistons.
I am having trouble finding any injectors with a 90 degree connector but Ebay has shown me that WRX and some small toyotas use them.
They must be able to flow methanol and will only be used at the track and fuel system will be flushed after every meet.
Any help and advice opinions pics specs etc would be apreciated.
NAth
10sec_rx7
Syndey
Re: Bottom Feed Injectors (Hi Flow Methanol) Advice needed Wed, 16 February 2005 03:23 Go to previous message
how much power do you plan on making? as 8x 550cc injectors on methenol wont make bugger all, you need 2.2 times the amount of methenol when compared to petrol,
s6 rx7 have the injectors you want with 550cc primarys and 750cc secondarys, note: these injectors will not last long with methenol in them,
my only susgestion is to get 8x indy blue 1680cc injectors and be done with it
Dale
Previous Topic:1G-GTE Is this all that's needed ?
Next Topic:Oil Sensor Location on 4age??
Current Time: Sun Oct 18 01:25:02 UTC 2026
Total time taken to generate the page: 0.0046119689941406 seconds
