Toymods » Tech & Conversions » Short stroke dampers
Rex_Kelway
Short stroke dampers Wed, 30 October 2002 07:35 Go to next message
Hello all,
Does anyone know of any companies that make adjustable short stroke dampers to suit an AE86 coil-over conversion?
I know TRD has their short strokes which are interchangable between modified '86 MacPhersons and the AE92 & 101 (Yellow i think). But these seem pretty hard to find (and expensive)
Tokico, which i'm pretty sure make TRD's yellows, has the HTS and a range of others which i cant really find much info on at all. But guru's the world over rave about Tokico.
A place here in SA spent a while on the fone to Koni for me (nice guys) then informed me that Koni can supply all the hard ware; Pair of damper cartridges (bound and reboud adjustable) to siut my requirements along with threaded sleeves, platforms and lockers for $300 a pair.
One downer though is that Koni's adjustment must be made from the bottom (take the whole strut apare for any changes - bad).
Someone must know something
Youngy
Eskilstuna, Sweden
Re: Short stroke dampers Wed, 30 October 2002 12:21 Go to previous messageGo to next message
I thought Koni made adjustable short stroke inserts (not specifically for the AE86, but if you have shortened the strut then from SW20 or RX7 etc, not to sure on that part) that you could adjust on the top of the strut in-car with that little clicker thing they use.
Rex_Kelway
Re: Short stroke dampers Thu, 31 October 2002 06:46 Go to previous messageGo to next message
From what the guy told me, one adjustment (bound or rebound) is made from the top while the other needs to be made from below.
dorikin
NE Melbourne
Re: Short stroke dampers Thu, 31 October 2002 07:51 Go to previous messageGo to next message
didn't you suggest a while ago the use of AE92 strut inserts cos of their similar dimentions, and when spaced up at the bottom provide far less travel??? i recall something like holding a five inch lowered spring captive...
Youngy
Eskilstuna, Sweden
Re: Short stroke dampers Fri, 01 November 2002 05:11 Go to previous messageGo to next message
Yeah Rex, I think you could be right only rebound is adjusted at the top of the strut (external).
I'll be able to confirm in a few weeks when I do this myself.
Cheers.
Rex_Kelway
Re: Short stroke dampers Fri, 01 November 2002 08:31 Go to previous message
Got a thing from the place about the new 8611 double adjustable motorsport inserts. The good thing is that they come in a range of different sizes/strokes.
They are adjusted from top (rebound) and bottom (compression) However they are not too hard to adjust. they require a 1/2inch hole drilling in the base of the housing so the adjustment screw can be reached. So you dont need to dismantle the entire thing to fully sdjust them.
One prohibitive aspect is cost however, the inserts are $500 each.
DANG!!!!!
Previous Topic:Microtech D5 fuel ecu tuning???
Next Topic:my log style aw11 turbo manifold....
Current Time: Wed Oct 28 18:02:28 UTC 2026
Total time taken to generate the page: 0.0038609504699707 seconds
