Toymods » Tech & Conversions » Air Horn Relay
rollaboy
Coffs
Air Horn Relay Wed, 30 October 2002 07:57 Go to next message
Ok i have copyed the relay pattern off the back of the relay. can someone tell what goes where, thanks.
http://www.plusoneinteractive.com/rollaboy/air%20horn%20relay.jpg
wilbo666
Re: Air Horn Relay Wed, 30 October 2002 08:13 Go to previous messageGo to next message
I have one similar that says as follows.
Top 87 = To +ve Compressor
Left (yours says 36 mine says 86) = To +ve of original horn
Right (yours says 35 mine says 85) = To Ground
Bottom 30 = To +12vcc (with 30Amp Fuse)
Not sure why mine says 85 / 86 instead of 35 / 36, so take this as a guide only, my guess is that this will work tho.
Youngy
Eskilstuna, Sweden
Re: Air Horn Relay Wed, 30 October 2002 12:12 Go to previous messageGo to next message
I spoke to a sparky friend of mine on this relay idea (as mine came with the airhorn kit) and we just dumped it as
a) The air horn compressor did not pull that much amplitude
b) You don't normally sit on the horn for that long anyway.
So just wired up the compressor with the wires from the factory horn set-up.
rollaboy
Coffs
Re: Air Horn Relay Wed, 30 October 2002 12:18 Go to previous messageGo to next message
Youngy wrote on Wed, 30 October 2002 23:12
Hehehe not in my case. My mates can't keep their bloody fingers off it.
[Updated on: Wed, 30 October 2002 12:22]
NeoNasty
SE. Melbourne
Re: Air Horn Relay Thu, 31 October 2002 11:06 Go to previous messageGo to next message
Hmm I dont think thats such a good idea..
The air horn does use a bit or power, and you dont really want much current flowing through those puny wires.. plus it will wear out the botton, due to sparks from the contacts...
I have air horns, and I think you really want a relay, Its easy to install, and you wont cause a fire.
-Shaun
AbaddonGZE
Re: Air Horn Relay Fri, 01 November 2002 02:45 Go to previous messageGo to next message
With the relay:
Take the original horn wire and hook it across 35,36 (the coil of the relay).. then run a nice big +12 off the battery and run it to one side of the "switch" and the other side to the +ve of the compressor, then the other side of the compressor to ground.
The relay will have a digram on it with terminals labeled.. it's meant to be a switch suspended over a coil (relays work by energising a coil, which then magnetically closes the switch).
Without the relay:
If the air horn compressor isnt too big, just common the two +12V and the 2 grounds from the original horns (most toyo's have 2 nugget horns standard).
You might want to make sure that the body of the compressor isnt connected to the earth wire tho.. as the standard toyota system is a constant 12V to the horn.. with the horn button grounding and completing hte circuit.
rollaboy
Coffs
Re: Air Horn Relay Thu, 07 November 2002 04:06 Go to previous message
Ok that diagram I made up was taken off a piece of paper that a auto elect. did and he must of read the relay worry as all of wilbo's matched up with the my relay.
I'm not using the origanl horn so where does that relay terminal go to?? And where the hell is the wire coming off the back of the steering wheel area for the horn....can't find it anywhere.
Thanks Brett
Previous Topic:Info needed Imported 1990 Supra
Next Topic:MZ21 centeral lock/alarm help
Current Time: Sun Nov 22 06:19:16 UTC 2026
Total time taken to generate the page: 0.006403923034668 seconds
