Toymods » Tech & Conversions » 1JZ HG Help??
grande91
1JZ HG Help?? Wed, 16 February 2005 08:21 Go to next message
Hi guys
i bought a VRS kit from toyota and the bloody HG that was in it is a single layer,.. has anyone used these??? it seems to me that it will never seal,..what did you do??? should i use it or get an aftermarket one??? and also what should i torque it to??? thanks guys.
cambelt
melb
Re: 1JZ HG Help?? Wed, 16 February 2005 14:21 Go to previous messageGo to next message
the part no 4 the vrs should be 04112-46030 from memory
and the head gasket shoud be about 3 or 4 layer mls
grande91
Re: 1JZ HG Help?? Thu, 17 February 2005 10:20 Go to previous messageGo to next message
3 or 4 layers it should be but its not,.. and before they gave me the 1JZ kit they made a mistake and gave me a 2JZ kit and the HG was the same Single layer,
anyone know the torque spec???
Re: 1JZ HG Help?? Thu, 17 February 2005 10:37 Go to previous messageGo to next message
2JZ head bolt torque spec is 34 Nm + 90 degrees + 90 degrees (in 3 separate passes). Can't comment on 1JZ but I'd imagine it's the same.
Use a marking pen and put a dot at the "front" of the bolt head (after you have torqued the bolt up to 34Nm) to give you a reference for each 90 degree pass.
[Updated on: Thu, 17 February 2005 10:38]
grande91
Re: 1JZ HG Help?? Thu, 17 February 2005 10:44 Go to previous messageGo to next message
aaaaaa good man,... so after the 34nm the 90part is twice am i right???
thank you very much for that....
Re: 1JZ HG Help?? Fri, 18 February 2005 06:44 Go to previous messageGo to next message
Leon that's right.
Just check and make sure it's the same for a 1JZ.....
grande91
Re: 1JZ HG Help?? Fri, 18 February 2005 08:55 Go to previous message
wil certainly do so, thank you....
Previous Topic:1JZGTE in 82 soarer what to do?
Next Topic:were to get a sard r2d2 bov in syd cheap
Current Time: Sun Oct 18 02:28:41 UTC 2026
Total time taken to generate the page: 0.0067658424377441 seconds
