Toymods » Tech & Conversions » help getting the 1g running
jcmunga
adelaide
help getting the 1g running Wed, 16 February 2005 09:54 Go to next message
kind of a noob question i know, but i dont know what i need,
putting the 1g into my ra28.
basically the 18rc was taken out and the 1g has been bolted up, i have no idea of what i need to do.
who can tell me what i need??
any help would be appriated
stevenvandecauter
Belgium
Re: help getting the 1g running Wed, 16 February 2005 09:59 Go to previous messageGo to next message
I guess you need a mechanic to get it running ?
Re: help getting the 1g running Wed, 16 February 2005 10:55 Go to previous messageGo to next message
Ummm, how about wiring and fuel?
jcmunga
adelaide
Re: help getting the 1g running Wed, 16 February 2005 11:20 Go to previous messageGo to next message
sorry should have been more specific, i know what needs to be done, just no how to get there, eg, new fuel lines, how do i tell which one is the intake and which is the return, i believe i can retain the origional return line from the celica, but need a new main line.
whats a good oil cooler to use, do i need one???
i will be needing a sparky for wiring as i dont want risk shorting stuff out.
do i need to use the origional air intake system??
Bugman
Re: help getting the 1g running Wed, 16 February 2005 11:22 Go to previous messageGo to next message
hmm t04e...
You may be able to get away with the standard supply line..
I am yet to see one max out.
jcmunga
adelaide
Re: help getting the 1g running Wed, 16 February 2005 11:24 Go to previous messageGo to next message
really?? if i use the origional i think ill need new piping made to go to the other side of the motor cos it opposite to the 18r
Bugman
Re: help getting the 1g running Wed, 16 February 2005 11:29 Go to previous messageGo to next message
un bolt it in the engine bay and you can bend it round the other side.
ofcourse this is alot easier without the motor fitted.
also heard/seen guys run it from one side of engine bay to other. I dont like the fuel being on the hot side of the motor though.
jcmunga
adelaide
Re: help getting the 1g running Wed, 16 February 2005 11:34 Go to previous messageGo to next message
what, they just run hoses over?? sounds like it would look ugly, i want it nice and neat.
so the origional one can be bent around with out any troubles?
Dust
Re: help getting the 1g running Wed, 16 February 2005 12:16 Go to previous messageGo to next message
Glad you are askin all the noob questions, saves me doing it Smile, quick someone answer the man Smile
jcmunga
adelaide
Re: help getting the 1g running Wed, 16 February 2005 12:42 Go to previous messageGo to next message
hehe, yeah i didnt really want to, but it came to it and it had to be done
680OST
Re: help getting the 1g running Thu, 17 February 2005 05:38 Go to previous messageGo to next message
You get "bundy tube" from a place like pirtek or enzed, you can buy it by the metre, its a copperc oated steel, and you can bend it with your hands. You'll need those little clip things that have a bolt or screw hole on one side, and wrap around on themselves with rubber in the middle, um, I don't know ho to explain it better, a company called WURTH makes them, you open them up, put the hose or tube through them. or even wiring, then close them back up and screw them to wherever you want, and the rubber holds them firm but cushioned.
Simply use the feed line that was there as a return, and make a 3/8" feed line to run up top the engine. You'll need a pipe cutter, a flaring tool for the ends, and possibly a little hand bender to do it neatly, all available from supercheap rather inexpensively.
Cheers.................6BOOST
PS Injectors sent today.
jcmunga
adelaide
Re: help getting the 1g running Thu, 17 February 2005 07:27 Go to previous messageGo to next message
nice, a detailed answer for a change, will have to get my ass down to pirtek.
cheers mate
Fattony
Re: help getting the 1g running Thu, 17 February 2005 09:18 Go to previous messageGo to next message
Couldnt have said it better myself, though i am a little sceptical about using copper coated steel as a fuel line as i dont think that they are a multi rolled tube like bundi is, hence no protection (so ive heard). All manufacturers use bundi tube for the fuel supply lines and id say vehicle manufacturs know a lil something about fuel systems Wink. Please correct me if i am wrong about the copper steel.
Cheers Adam
680OST
Re: help getting the 1g running Fri, 18 February 2005 05:28 Go to previous messageGo to next message
The Bundi tube that these guys sell/use is safe to a few thousand psi as far as I know, they use it for some hydraulic stuff, but its definately up to the job, i've seen brake lines and fuel systems we built 5 or 6 years ago still fine, so it should be easy as.
Cheers..................6BOOST Smile
John S
Re: help getting the 1g running Fri, 18 February 2005 11:55 Go to previous messageGo to next message
Check out Sixworks or Sideshow for wiring though; an autoelec is likely to stuff it up or charge you heaps.
Bugman
Re: help getting the 1g running Fri, 18 February 2005 20:21 Go to previous message
seriously there are about 5 good write ups on how to do this conversion let alone the countless times it has been covered on the forums.. try dig that up first.
Previous Topic:ST185RC Brake rotors
Next Topic:brisbane 2tg bearings gaskets parts etc??
Current Time: Sat Oct 17 21:22:41 UTC 2026
Total time taken to generate the page: 0.0064089298248291 seconds
